What the heck? It's less than lunch!
I'm confused (it's not hard to do!) 😱
This 7297 seems to be surface mount: 2 15W TDA7297 Dual Channel 15W 15W Digital Amplifier Audio Amplifier 12V | eBay
But most are through hole:
AC DC 9V 15V 12V 15W 15W TDA7297 Dual Channel Amplifier Board Module Version A | eBay
Which is the "real" 7297?
Hi Jeff,
The photos are difficult to make when the chip is on a heatsink, which causes a weird shadow and strange viewing angle for the camera. It is the same chip on both boards. The difference is that the surface mount board is both upside down (resistors on top) and far stronger dual-layer construction with vias. The through-hole board has all connections trackside and is single layer; and it would allow you install your own choice of input caps if you wanted to play with it. Anyway, there's some board variety, both with same chip.
Hey guys, this might be a bit OT but does anyone know what chip is in the Lepai LP-V9? This unit must be the best buy of all - 2 x 18W, USB/SD Card MP3/WMA, FM Radio, remote control all for 17 USD or 11 UK Pounds including shipping.
See here
I have one, but it's nothing more than a 2013 version of the transistor radio. 🙂. Good enough to throw in the picnic basket, with a pair of small speakers, but beyond that nothing stellar. It's very cheaply made and looks it too! I bought it because of all the noise about the Lepai brand. I gave it to my son to play with.
I have decided to do my first bit of modding, ever.
I would like to take the board out of a SMSL 2020 amp and insert the 7297 but the heatsink sticks up too high.
What if I removed the heatsink, added a piece of alumininium angle and then attached the heatsink to the angle? This would make the heatsink parallel to the board. Or, I could remove the heatsink, add an aluminium angle and then screw it to the inside of the case, making the case the heatsink?
Thans, Terry
Thans, Terry
Terry,
You could easily get by with a simple piece of aluminum angle. I would remove the HS altogether. Remember, these are only 15w amp modules, so the amount of heat generated should remain low, unless you really push them for long periods of time. 🙂
You will note many other amp projects here on the forums have used a piece of aluminum angle as an easy alternative to sink the output devices (monolithic packages or transistors) to the enclosure.
BTW, my 2 modules arrive today in the mail, so it's time to give them a test. Now where did I put that AC adapter...
Rick
I find it just a bit weird that the module produces such nice results from a simple set of ceramic disc input caps. Potentially, the imaging might be more entertaining if those parts were replaced.
In general, do you guys really notice an improvement in imaging with change from basic ceramic input caps to polyester film caps or boutique $$$ caps? On another amp (tpa3116d2) I am using stock recommend SMD ceramic input xr7 1uF caps and the imaging and detail on the amp are just wonderful to begin with. Can it be improved or is this like the whole upgrade with big expensive speaker cables vs lamp cord or cat5 cable? Maybe a little OT....
I guess my ears aren't as golden as they use to be. 🙂 I'm really not one to try and wring out the last bit of SQ - if there's 'truly' any to be had - by swapping out components. Sure, I know there are some to consider, but at that point the differences have to be very subjective (as opposed to demonstrable) to the listener. And how would you ever do any A/B comparison of the two components?
I'm more an 'integrator' builder and like to put the puzzle pieces together in a nice, completed package. If I can reduce the hum in my builds to a negligible, inaudible level I'm happy. 🙂 Otherwise, to my ears many of these little monolithic amp modules sound pretty much the same. Although I'm becoming partial to Class D more and more. I believe speakers and placement tuning play a far greater role in how we hear our music as opposed to whether the capacitors used are ceramics or polypropylene, but I won't argue with the designers who know where to use which type!
In general, do you guys really notice an improvement in imaging with change from basic ceramic input caps to polyester film caps or boutique $$$ caps? Can it be improved or is this like the whole upgrade with big expensive speaker cables vs lamp cord or cat5 cable? Maybe a little OT....
If viewed as "compensation" all such things make sense, albeit some may be quite indirect and/or misleading. Let's please postpone "tweaks" until after the amplifier is running from clean linear regulator power.
Earlier, on Activexp's amp, I saw an AudioWind Regulator or ElectronicsSalon regulator, and that looked a reasonable and perhaps important first step. At those stores, I'm fairly sure that Juli and crew have checked the quality and that chip regulator is authentic and measures within specs. That board has an AC input for a transformer; but, as an alternative, it also has a DC input which could be powered by a CRC linear supply, an SMPS, or a capacitive multiplier. So, you do have multiple options.
After installing reasonable linear regulated power, the linear audio amp will be more directly informative about which tweaks are actually useful. When it comes to flea power hi-fi: Regs first. Tweak later.
Meanwhile, back to tweaking:
At small signal input, Ceramic Disc caps (like came with my board) have, perhaps the most beautiful level crisp tone ever. But they can fail at imaging depth. Running a close second on tone, but with greater depth, is the old faithful polyester dip cap, popular for use in tone controls. Larger polyester and electrolytics alike have treble droop. SO, a smaller value ceramic may be teamed with a polyester in a conglomerate effort. Or, tiny plus bigger polyester caps can be teamed together. For box caps of 220 nanofareds 224 I have no idea. But, the 330n red Wima is okay for a box cap. I don't know if it will outperform the existing caps though.
The caps on the SMD board might not need replaced. And, there's a chance that the ceramic disc caps on the through-hole board might not need replaced. But, the only way to find out is to try it.
However, I would not bother replacing the factory caps if the amplifier is running from a cheap SMPS. That's because I don't want to close the barn door after the horse escaped.
Sorry for late response, been too engrossed with the remarkable 7297!
Thanks for the insight re the LP-V9, was thinking of getting one to tinker with but don't think I'll bother now. I rather fancy a headphone amp kit instead 🙂
Do any of the gurus on here know if the 7297 chips can be paralleled (I think that's the technical term for increasing the power by using more chips)?
Try this
Amplifier PCB board TDA7294 Amplifier board(1+1) Dual channel 2*85W-in Printer Parts from Office & School Supplies on Aliexpress.com
I purchased and received a pair last week, how could I not for the price?
I have been comparing them to the 7297 which I love but I cannot detect any audible difference between them. I guess it depends on how much power you require.
Still liking the less than lunch amp
I am liking this $6 amp too. It is in a $2 enclosure with $2 worth of speakers. I hope it sounds as good on the $4 PSU I am waiting for as it does on bench power. Counting a jack or two I have yet to install the whole project will come in well under $20.
Me too, MeTarzan!
.......I'm still liking mine. Can't seem to take it out of the system it's so darned good!
I've played it many weeks now. Bass is great, mids and highs accurate and non-fatiguing on my Klipsch La Scalas. And, ZERO background noise. Can't beat that.
I see they've changed the inputs from mine which is two RCA jacks (L & R). Now these come with a single jack, which I am guessing is similar to a headphone jack.
Still $6 delivered though. What are you guys waiting for?
Mark
Try this
Ah yes, I know the 7294 very well and have a couple of amps based on that chip. The sound quality is first class but to my ears the 7297 is slightly different in a very pleasing way and continues to impress for something so basic. Remarkable for a chip that was designed for TV's and portable radios!
I've switched back to the 7297. I have not Guilded the Lilly by building a box for it yet, I might just screw it to the back of my equipment cabinet, out of sight, with the pot just visible. I leave it on all the time.
Yes, the TDA7297 easily outperforms the generic datasheet schematic for TDA7294.
TDA7294
However, it may be fascinating to notice that the more powerful chip amplifiers, like TDA7294 and many more models, all share almost exactly the same generic schematics in their datasheets, despite the many different chip designs; and, that means that there's a lot of kits and even quite a few productions amplifiers suffering nonspecific support, aka junk. Those generic schematics show you where the parts go, but not how to optimize the audio quality. Non-specific support causes hot running, odd tone/coloration and sometimes frailty. That's the usual condition of most kits, and some are worse. The chip is fine, but the schematic is junk, so I made a different schematic for it.
TDA7297
One really unusually good thing about the TDA7297 is that it runs very nicely on the simple datasheet schematic and the only quirk that I could find is that it needs a rather high value potentiometer, such as 50k~100k range, which conveniently comes with most of the ready-to-use kits on ebay. This particular chip's input circuit promotes nice level sounding audio without having to add a buffer. It isn't that the TDA7297 has great specs. It sure doesn't. However, the good sound is mostly coming from the fact that it runs near optimal on the datasheet schematic, and that is rare. A linear regulator is a good upgrade for it, and with that sort of help, it does some passable hi-fi. So, the main deal is that the TDA7297 is almost effortless to use for obtaining good results expediently.
Still very happy with my lunch money amp. It's now housed with a USB/MP3 player with FM tuner and it all works very nicely. This module was hopeless with a class D amp as the high speed switching caused interference on FM drowning out all but the strongest stations.
NICE!
All I've done with my board is to place it on a piece of non slip mat, dabbed a black felt tip on the led and hid it behind some CDs. I leave it on all the time.
I had the same problem with FM on both a Lepai and an SMSL 2020 amp, not so the tda7297.
I still cannot get over how good this amp sounds, and it must sound good, none of the modders have made recommendations.😛
