I'm looking to build a Haller attenuator and need to source a 100K ALPS Blue Velvet. A search on Mouser brings up the following:
RK27112 | Mouser Electronics, Inc.
Can anyone tell me which of them is the "correct" one? FWIW, I'll probably just couple it with a standard 1/4" knob so I'm assuming that a 6mm shaft diameter is correct. If I'm incorrect in this assumption and/or if I'm looking at the wrong part altogether, please let me know. I'd like to order from Mouser so that I can include some RCA jacks, resistors, etc. that I need for other builds.
Thanks in advance for any/all feedback.
There is a set-screw on the knob so it'll work out fine then. Any thoughts on which is the correct part? FWIW, I'm looking at this one now:
RK27112-S20C1MN104 (RK271122004D) ALPS | Mouser
Ask here: ALPS Japan Bauelemente Potentiometer Schiebepotentiometer motorisiert IR-Fernbedienung Set Faderknöpfe AudioShould be what I need. 100K, dual-ganged, audio taper.
And they have shop on eBay:
ALPS Japan Motorpotentiometer, Fader Motorfader Crossfader items in ALPS Japan Potentiometer kaufen store on eBay!
