Here is a video that I shot at Danley's HQ of a speaker comparison demo. The top is a Danley SM80 with a TH212, TH118, BC412 comparison. Hope you enjoy.
Danley Sound Labs Subwoofer comparo - YouTube
As one would expect, the BC412, having less LF extension, larger cabinet volume and frontal area and half the impedance is louder.
Do you know if the tops were delayed to properly time/phase align to any of the three subs in the test?
Yes, certainly correct. No time or eq adjustments. Just a band pass for subs (same for all), and probably a high pass for the top.
So, in addition to the BC412 having less LF extension, larger cabinet volume and frontal area and half the impedance, it's shorter path length probably would make it sound louder than the others due to the Haas effect.Yes, certainly correct. No time or eq adjustments. Just a band pass for subs (same for all), and probably a high pass for the top.
That would be a question that Ivan could answer better. I did some other videos on my YouTube page of Danley speakers if you'd like to see them.Wayne Phillips - YouTube
