HP amp out impedance vs. HP impedance
Joined 2009
Hi !
sorry if the issue has already been discussed
But in an old review of the Grace m901 headphone amp I read the following statement
... The 901 uses a high-current output amplifier with an output impedance of 1 ohm and is capable of driving 8 ohm loads.
Perhaps because of its low output impedance, the 901 has the best low-frequency control of any headphone amp I have heard.
Is this statement correct ? I would like to get a nice low-frequency control on my low Z headphones so I would like to know if an amp with a very low Z out is mandatory.
Thanks a lot for any kind advice
Kind regards,
gino
Thank you very much indeed for your kind and valuable reply
What i do not understand is why low Z out amp are not very common while a lot of HPs around are indeed low Z
For instance I am listening to a HP of 55 ohm with an amp with a Z out of 10 ohm
The bass is very unsatisfactory in terms of control
The very same amp drives much better a 250 ohm HP by the way
Is it so difficult to build low Z out amp ?
This is extremely strange to me
Thanks for the very interesting article and regards,
gino
Some headphones are designed to comply with the old IEC61938 specification, that headphones should be driven from a 120 ohms source impedance irrespective of their impedance. The AKG 701 is one example. It sounds far more tonally balanced when driven from a 120 ohm source impedance, (although a few prefer 100 ohms.) You then need an amplifier with higher voltage drive capabilities for best results . Those using + and -15V ( or even + and - 20V) supply rails are a good choice.
SandyK
Ok but i would very much liked a comment on the quoted statement
If the low frequencies are not controlled I am quite sure that they will blurred all the other frequencies
A low damping of the driver will cause the driver to have some kind of ringing
For me this is extremely clear
Nevertheless I would like to get a confirmation from experts
I think this is a fundamental issue
And sorry but to say
is a little generic
Kind regards,
gino
is a little generic
Kind regards,
gino
Gino
There are quite a few members of a U.K. based forum that own K701s, and that is their general consensus. The K701s when driven from a much lower impedance source are far too detailed and fatiguing for long listening sessions. The same applies to the Audio Technica W1000 that I own.
Alex
It would be nice to have more info
For instance a list of amps that make those HPs sound good
Saying that an amp with 120 ohm of Z out is needed for the best sound from that AKG is a little vague
And it would be useful also to know which low Z out amps are not good for the AKG
I say this because a friend of mine had a Melos Sha Gold HP amp, a vey low Z out unit but a very high quality one
It was just splendid with both Grado 32 ohm than Beyerdynamic 250 ohm
Fatiguing for me means usually distorting
Kind regards,
gino
Thank you
But so do you exclude that a low Z out amp can make the K701 sound very good ?
I am quite obsessed about the danger of muddy bass that over imposes itself on the rest of the band
And actually i have found usually better the bass of high Z HPs, like 250 ohm HPs
Kind regards,
gino
Might want to consult Richard Marsh's article in Linear Audio Volume 3 -- an HP amplifier and equalization scheme.
Actually my knowledge and ability to understand is very limited
I just wanted to get opinions about the statement quoted at the beginning
For instance, i sincerely do not know if a comparison with loudspeakers and HPs can be done
We tried a same speaker with a tube power amp (high Z out) and then with a solid state power amp (very low Z out)
The performance in the bass was completely different with the SS am much much better
The SS amp had a grip on the woofers that the tube amp did not match at all.
As to find low Z out amp is very very difficult I think that i will solve with a 250 ohm HP and a normal amp
Thanks and regards,
gino
