Hi nice people at Diyaudio
I'am restoring a vintage SX-434 with a rather noisy phono stage.
Some say that the older Toshiba BJT's is getting noisy'er by the
time or maybe modern types are just better.
Would it help to replace the transistors with some modern type, say
BC550, or is this simple configuration just noisy by design.
spuncut
spuncut
When you open a reply window, go down to manage attachments and attach from your files. Try and use images around 100K
Good transistors for phono stage use would be the SS9014/15 pairs. They are designed for this type of use. http://www.google.com/url?sa=t&rct=...QDF8x7TL5aXzS3a8Nk-GuqA&bvm=bv.45373924,d.b2I
Thanks 🙂
Any point in replacing the resistors to metal-film types ?
512-KSC1845FTA from Mouser. Check the pinouts
No need to change the R's until you you figure out the noise source.
Yes both channels, no pu connected, no noise on aux, hiss, no hum.
I was wondering if it is true that these transistors should get noisyer at old age ?
- Noisy phono stage on vintage Pioneer SX-434
