Hi Everyone I just joined the forum (Ive been reading it for weeks so thought it was about time) I had a moment of madness on Ebay (as you do) and bought a 2.1 Class D amplifier. Please see my question and specs below
Specification:
Here is my question,
I need a small (light weight) power source for it, I had in mind a SMPS but im not sure;
A. Is it possible? it wants AC28-0-AV28 input but SMPS are DC?
B. Ive read a lot about recommended power and believe I need 600w for this amp
C. Please dont make me put a Toroidal in it, im trying to keep the weight/ size down 😀
Chip
Specification:
- Work: Class D
- Quiescent Current: 65mA
- Work efficiency: 90%
- Left and right output power: 2 * 150W
- Subwoofer output power: 250W 8ohm
- Frequency response: 20Hz to 20KHz
- Operating voltage: Dual AC15V to AC28V
- Recommended supply voltage: AC28V-0-AC28V
- PCB size: 150 * 145MM
Chip
If the amp is taking in AC then there must be smoothing capacitors on board.
An SMPS might take exception to that.
I would use a 40-0-40DC SMPS but remove the big smoothing capacitors from the amplifier pcb.
Is that the black caps in this picture?
Why would you go for a 40-0-40DC? (just curious)
See Crest factor - Wikipedia, the free encyclopediaWhy would you go for a 40-0-40DC? (just curious)
28 VAC * √2 ≒ 39.6 VDC
BUT: According to the datasheet of the TDA8950, ±40 V is the maximum supply voltage this chip can handle. So I'd rather go with 36/37 VDC (as suggested in the datasheet) to leave a little headroom, just in case. You'd lose some 10 % of the maximum output power though, but you are on the safe side. Edit: The 2x150 W given in your description are at 4 Ω with 10 % THD and VP ±37 V.
Disclaimer: I'm not an expert, so corrections to my assumptions are very welcome. 😉
can anyone tell me how the audio input system in this amplifier..... ummm... works? i cant think how a jst plug can fit to an audio socket of any kind, or am i acting really stupid and it's plain obvious!!?? thanks
