I'm trying to build the large square horns to replace the YL Acoustic MB90's I have now.
Are there plans anywhere? I know I could use a calculator, but I thought I try for already published plans first. 😀
What do you want to do differently, besides spend less.
Lets see the MB90's, I can't find pics on the net.
Yahoo Japan has plenty of pics.
?yl mb90?????? - Yahoo!??????
Japan, yeah - got it.
If that's a "French Horn" above I'd ask JMLC if he could point you in the right direction.
I made some drawings for another member of a JMLC mid-bass horn awhile back, but that was quite a bit different than what I think you are after.
Hello Datubie,
Send me a message to :
jean-michel.le_cleachXmines-paristech.fr
replacing the X by the arobase.
So I'll send you the Version of my excel spreadsheet that give the planar cuts of one facet of a horn made using facets (gramphone style).
Also I'll send you an excel spreadsheet to calculate the adaptor from a round compression driver outlet to square (in fact it allows "round to rectangle" adaptation).
Best regards from Paris,
Jean-Michel Le Cléac'h
I'm going for 125hz, but might have to settle for 150hz due to width constraints.
What is the flare of those white horns in the picture? Looks like 200 Hz midrange horns?
- JMLC mid bass horns
