Hi
Anyone know where to find a datasheet of these mecrury wetted relays?
Clare 851 A24 B1A
Clare 951 A24 B1A
Brgds
Pix 🙂
Clare 851 A24 B1A
Clare 951 A24 B1A
Brgds
Pix 🙂
I believe CP Clare was aquired by Ixys (?) and either before or after that divested of mercury wetted relays altogether. Searching for datasheets on the CP Clare web pages are thus probably futile. Your best bet is likely to search elsewhere on the web or try to find out how CP Clare divested of their Mercury business + follow that trail.
Yes Petter,
But I have tryed that and come to a dead end..
So now I thought some of you guys had someting stuffed away someware.
Bregrds
Pix
Sweden😀
Bregrds
Pix
Sweden😀
I have the 1977 catalog sheet for the 851 and 861 series.
It might be hard to scan. May have to take a photo.
Write me
grafkc
cox.
net
Write me
grafkc
cox.
net
Previously sorry for my bad english. I haved seen that you have 851 catalog can it be possible to you to send me an copy. Thx
In my drawer are some Clare mercury wetted relays (made in Tongeren, Belgium) with the type number HG-1047. It has an octal foot, with a diagram indicating:
1, 2 = open contact
3 = source
4,5 = closed contact with 3
7,8 = activating voltage
Does anyone have data?
1, 2 = open contact
3 = source
Hello i try to find datasheet of CLARE 951 series especifically 951 A24 B3A i see the document of 851 and 861series one of both is like A951 series?
thanks !
thanks !
The CLARE 951 series relays are not mercury wetted reed relays, they are dry reed relays. Do you need the catalog page?
yes, i need the datasheet of the relay because i can`t find it on any site, i appreciate your help.
thanks
thanks
So grateful
Thank you so much Speedskater for that datasheet. I've been looking for a long time. Kudos.
At long last I found the catalog!
Hope it's big enough.
Hello,
(I'm new here - sorry for bad English)
Thank you Speedskater.
I was looking for any time for the data sheet for this old relays. The only point I've found it was here in the forum!
Thanks!
Best regards
Maris
Thanks!
Best regards
Maris
I have some clare relays 851 ..... all NO relays.
I was looking at The Preamp rom Elektor and most of the signals are switched with the NO relays, no NC contact needed.
However, there are a few were ther are NO/NC relays used to switch the audio signals.
Is there a way to make an NO/NC relay from a couple of NO relays. I asked AI perplexity for an answer and let me say he didn't get it or his answers were incorrect. So I like to ask my question here. Can with the help of extra logic and power this be done?
My crazy idea:
- Design & Build
- Parts
- Clare 851 A24 B1A Mercury wetted relays
