Convert 21V to 15V dc to dc
I need a schematic to get 15V from 21V dc.
I know how to get that with LM7815 but with that I can have only 1A. I need something for 4Amps!
I need that for small power amplifier. I already have transformer with 15V secondary that gives mi 21V dc. Power IC's are rated at 15V so 21V will probably destroy them 🙂
Some of the older 7815 datasheets have a circuit that will allow you to "wrap around" a power transistor and get more current.
If you measure the ac voltage of the transformer you get 15V eff. If you rectify it and put a cpapacitor you get approx. 21V (with no load). That's the peak value. If you draw some current it will decrease. If you put a linear regulater, it will dissipate about 15W @ 4A.
21V To 15V
I simulated a simple regulator with LT-spice.
  • Gleichrichter_Elko_15V.asc
I was not sure what was good for audio because some years ago I have made something with transistors but it was not good because it was bad for the sound so I did it with lm7815 and used it wisely! 😀
Someone mentioned LM317 so I have found a schematics here:
24v to 12v converter | Power Supply Circuits
I did not used that much transistors of course 🙂
It worked fine under load of 3 amps so I just need to test it with amplifier and music.
