Stajo,
If tweakingb is where your at, i would try signal rrsistors on actual buffer first. Rhopoint makes nice ones, as does Texas instruments. Rhopoint is in your leg of the world. There is fella in article section that just tried them as IV. Did a little writrup.
Rhopoint
Thanks mate. Any of those you had in mind? http://www.rhopointcomponents.com/p...RESISTORS&subcategory=Precision+(through+hole)
Strange, its seems like they have odd series. 200, 250 but not 220?
/Staffan
Staffan I believe that the difference between FT3 and FT1 is only their voltage rating.
That being said, I had great results using them both as coupling and as led filters. So either way, you are going to have fun 😀
RESISTORS Precision (through hole) 3ppm/°C wirewound squaristor GR102 / GG102 series
I dont think the exact numbers are a big deal. 250 should be fine, but ask Salas to make sure. I am by no means saying it will make a profound change, but at least they measure really well.
This thought has me curious... I purchased a pair of spendy .22uF Jensen Copper/Paper/Oil caps. I got in the mail a pair of .022uF Jensen Copper/Paper/Oil caps. I called and advised and now I have the pair of .22uF Jensen
The seller would have to pay for the shipping to have me send him back the .022uF Jensen. I called him and told him if he gave me a deal I'd buy the .022uf and save him the $ to ship them back
So thinking about just running the .22 and .022 uF parallel on each channel. just silicone glue the .022 piggy back on the .22 and solder parallel.
It may help their dissipation factor in the end. All you got to do is to try the single bigger cap VS the combination and decide with your own ears in your own system.
I got my kit today from TeaBag... Going on a vacation and will probably start building in a couple weeks. The kit now has 10,000uf caps
Nice Bambadoo, just be careful on those beyschlag resistors. They seem big but start sweating at half a watt or so.
Yes I know.. I have 3 of them in parallell right now and some mills.... to get close to the desired value...
Anyway:
Well that was in my closet.. Have some good resistors in order.. Will fix that..
The NOS beyschlag carbonfilms sound so nice in my tube gear.. Actually I sometimes prefer them to Audio Note 2w tantalums..
In my 12b4a preamp I test I use 2 of the beyschlags in parallell. They should dissipate 2.25w according to my math and they get quite hot yes..
Anyway:
They are really nice at some places. Carbon oxide I beleave tho. A bit like those rebranded KOA Speer SPR2 that people buy for the big buck called Kiwame.
So I downloaded the free version of Sketchup yesterday and this is what materialized from the ideas in my head. I have already ordered the Zebrawood from woodcraft.com and i am in the process of working with cut2sizemetals.com for the copper. The copper will be .125 (1/8) inch thick and the zebrawood is 1/2 X 3 inch. The "bar" on the bottom of the front panel is 1/2in pure copper. The front panel will also have a large volume knob (haven't decided on material yet) and a small LED. The back panel will have a fused IEC inlet and RCA jacks.
If you haven't tried any 3-D graphics program, "Sketchup" seems to be a good place to start. I learned the software in a half hour and had this model made shorty after.
Oh yeah, the top plate will have to be machined to have vents. I am working in AutoCAD right now to give to a local company or 'Front Panel Express'.
Any comments or ideas would be appreciated.
-Madison
-Madison
Here is the layout for the top cover. I think this will look amazing in lightly polished pure copper... And being 1/8in thick isn't too shabby either..
Finally placed an order for a fully shielded and encapsulated toroidal transformer (80VA 2X15V) from SumR.
The transformer will take around 2 weeks to arrive, so in the mean time I will focus my efforts on my chassis and a few other things.
I have not yet made a decision on a chassis for my build. You have some unreal idea material where you are going. Please take some photos of this when you get going!
Knob? Audio Note Gloss Black would look nice:
knobs_audio_note
knobs_audio_note
Nice Madison. I love the zebra wood, although I must admit that I prefer the zebrano wenge for my audio equipment 🙂
I'm back to thinking I'll run my DCB1 with a Pot on the input side of the DBC1. I was thinking of the Khozmo 25K to keep the input impedance a little higher and friendlier on the way into the preamp I'm building.... I think the 25K is a little on the higher end of the recommended range with that recommended range being more 10K - 20K.
Is the 25K ok?
Is the 25K ok?
- Analog Line Level
- Salas hotrodded blue DCB1 build
