analog 3.5mm to digital usb possible?
If I don't have this in the correct section folks, my aoplogies...
Looking to find out if anyone has done this or knows a device that will.
  • I have a GPS unit that has turn by turn directions through an 3.5mm analog output plug.
  • I have a Sony headunit that has a USB digital input on the front of it.
  • Is there anything out there that will allow the conversion of the analog to digital signals? I find a ton of stuff the other way around but not A-D
Any help would be appreciated.
I am using a PCM2902B USB Audio Codec in a portable design, it works great with WinXP. Another Burr-Brown masterpiece. Used the hi-performance regulator option exactly as shown in the app notes & eval brd. Only 16-bit however, but it is fine for what I need.
Rick
