SE 6CB5A amp with 6N7 driver
Hi Matt,
no ASC caps in this version. This is going to be a low cost implementation, so no oil caps but electrolytics. The wooden cap will cover the power transformer. The first versions of the wood cover is not made of solid wood, it is veneered. But I plan to get them made from solid wood like the chassis frame
Best regards
Thomas
Thomas,
The ASC oil caps you use are not expensive but they do take up real estate. Why not ultrapath connect the electrolytics? You could step them down to 30uF though the voltage rating would have to go up. Just curious.
Matt
Hi Matt,
as this is supposed to be a low cost design, each part needs to be looked at. And while the ASCs are not very expensive, it adds up and as you mentioned they need real estate which drives up the chassis cost. You could argue the same about interstage transformers, they are not that expensive.
The same for ultrapath: it would add to the cost significantly since it requires decoupling of driver and output stage to be cost effective. I already presented a design which is a step up in cost and a significant improvement in sound performance. It can be found where:
VinylSavor: Making of a SE 6CB5A amplifier: circuit
At the end everybody can make his own choices. Since I usually show designs with little compromises, I wanted to show an amp that is at the lowest possible end of the cost ladder but still providing good sound.
Best regards
Thomas
Thomas,
I guess I should have gotten to the point. I like ultrapath as well but I have never listened to an electrolytic in that position, I was curious if you had. I have never A/B'ed electrolytic bypass with electrolytic ultrapath. I've tried MKPs as ultrapaths but didn't like the sound.
Matt
Hi Thomas, if you have a electrolyt as the first cap in you powersupply after the gratz bridge, and then isolate it from the amp circuit, with a coil and proper decoupling, will you still be able to hear that first electrolyt?
I guess the function of the coil is as much to prevent the music signal to go though the electrolyt as much as it is there for noise filtering, or am I completely off hear?
By the way I love the way you build you designs, but they become so expensive.... 🙂
Hi!
You will probably get different opinions on that. I would say the electrolytic would not be very audible. But I haven't tried. I either built all oil caps or all electrolytics
Best regards
Thomas
