I am actually considering making such a board, I just do not have the time needed for making such a board at the moment.
However, there will be a Bragi MKII sometime in the future.
Changes would be getting rid of the volume pot, it is not really needed and I am not even using that option myself, I just put jumpers in instead of the pot.
So basically, remove volume pot, add AD1896 + supplies for it, change crystal to 24.576MHz, possible using U.fl connectors for the digital input. Then I would have to rearrange a few components and it should be done.
But it is just an idea I have, maybe I will have something to show a few months from now.
I search Taobao for ES9023. Maybe it comes to Ebay ? Maybe no.
US$30 TE7022L+ES9023 USB DAC ´øͬÖáSPDIFÓëI2SÊä³ö-ÌÔ±¦Íø
The TE7022 is not supporting asynchronous USB. I'm wondering if there is a similar (in terms of cost and performance) chip that runs asynchronous.
Regarding Tenor: E.g. Audio-GD pretty quickly got away from those asynch TE80xx Tenor chips, which were supposed to be even better, though more expensive , then the TE70xx ones. ( Now they use VIA Envy VT1731 - no, no XMOS)
CM6631A is asynch and not expensive.
Indeed, and it supports every common combination of sample rate and resolution, all the way up to 192/32.
It was an easy choice for me.
BTW, soundcheck, the CM6631A works perfectly plug and play with kernel 3.7.6. Full USB2Audio mode all the way up to 192/24. Without a hitch.
Interesting. I'd guess a 39$ DAC with async USB and some of those tweaks that's been discussed over here applied, looks like a very appealing device.
Perhaps somebody should give HifiMeDiy a hint.
Though I'm not sure if the ADUM isolator of the DAC 2 -- which seems to be doing quite a good job -- would still work with the CM6631A.
Cheers
Cheers
I'm still using my SBT Touch with Toslink out to the DDX320.
Havn't found anything better yet.
A USB dac I'd use as backup solution. But it's good to know that those work under Linux.
Cheers
ADUM4160 can work with the CM6631 (plug device into iso, switch on iso, plug iso into PC) but it switches the driver into a slower speed so the device becomes limited to 96/24. I haven't managed to get it to work with CM6631A. (31A supports 176.4 but non_A doesn't)
Hi All,
Just a novice to DACs and had been looking at the various ebay cheapies and some lower end Fiio ones, though most of their models need an extra RCA/line adaptor.
Now found a link to this thread and the UAE23, which description was a bit confusing as it says Usb to Optical, though its seems the output connector is a jack that can be used as a line output at 2v - correct ?
Having read though all 28 pages of this thread it seems the UAE23+ model is perhaps the better model ?
Seems the advantages of the + are the volume control, RCA output sockets, isolation and external psu.
Wondered if you all agree the 23+ is the better option for a desktop system ?
Although not mentioned expect many of you are also now on W8 so wondered if there were and driver problems there ?
I'm looking to connect to an Arcam amplifier but it needs a 5 meter cable, so wondered what is the best way to do that, a long USB cable, long interconnect or 50/50 ?
Finally one for the EU guys, notice the HifimeDIY says they can post out from Belgium, but could not see any option to select in the checkout area, do they automatically send small orders out via the Belgium route ?
thanks
thanks
If only for desktop use, I would choose the UA23+. It is better for future tweaking if so desired.
The output is at a low impedance, so a long interconnect for the audio will not make any noticable difference. But then, this is DIY. Try either way and let us know your results.
For portable laptop use, the UA23 is so convenient. In fact, I would have both, as the price is so small.
I have ordered a second UA23 to the UK a couple of months ago directly from Hfimediy. It was first shipped to Switzerland, then to the UK. Hfimediy choose this route.
Thanks for the reply, looks like its the 23+ for me then.
Interested to know if you had any import duty/vat to pay and how much the Royal Mail added on, partic as Switzerland is not in the EU so think like from the Far East anything over £18 is liable for duty ? or were you lucky and it came though ok ..
- Digital Line Level
- Hifimediy ES9023+TE7022 24/96 USB Dac
