I thought it was against the rules to post in a language other than English without a translation."Ceci n'est pas une pipe."
but I see that perhaps you are getting the gist.
It is also against the rules to deliberately post incorrect information ...
No, it isn't- it's not deliberate, it's a matter of our current postmodernist view that one doesn't really have to understand something in order to have a valid opinion.
There's all sorts of misinformation posted here regularly. The only type that's censored is that which is a safety hazard. It won't hurt anyone if a poster is blithely ignorant of basic math, physics, and engineering- other than the poster himself.
Erin, why dont you look at some of the links I have posted, then you may understand digital electronics a bit better.
I am of the opinion that surely some of the stuff on this thread has to be intentional! Opinions that are stated as facts really get to me.
I think I need this book:
Post-Fact Society
Why has punditry lately overtaken news? Why do lies seem to linger so long in the cultural subconscious even after they’ve been thoroughly discredited? And why, when more people than ever before are documenting the truth with laptops and digital cameras, does fact-free spin and propaganda seem to work so well? True Enough explores leading controversies of national politics, foreign affairs, science, and business, explaining how Americans have begun to organize themselves into echo chambers that harbor diametrically different facts—not merely opinions—from those of the larger culture.
If you didn't like the battlements, how about this?
Q:When drawing the horizontal line, and the vertical lines, where were the sine waves involved?
A: Nowhere
Perhaps a course in freshman physics and math might be of use? There are also online sources of instruction in how to do Fourier series and integrals. It is one of the most useful tools in science and engineering to understand how signals work.
A: Nowhere
wow! and you guys call us closed minded.... then again, whats a little subterfuge between friends. you should be looking closely at the light used to create that image to see the sinewaves, not the ideal fictional and iconic representation your brain is telling you you can see. again with the irrelevant attempts to be 'smart' by changing the point of reference, this time to visual. you are suffering from synaesthesia?
No, nothing like that, I think it's just a matter of seeing the need to learn the basics before talking about it.
What we have is someone who draws the numeral 4, then triumphantly demands that people show him where he used two numeral 2s to make his drawing. That is not someone suffering from some Latin disorder, it is someone who ought to put his brain toward learning arithmetic.
I was being silly/facetious with the synaesthesia thing, its not often you get to use a word like that =) its a very interesting condition, also brought on by the use of certain very strong psychedelic drugs 😉 and some cancer medication. the brain confuses the senses, so you can see sound, taste colour etc.
but i'll just simply put
x 2, very succinctly put
Don't drag numbers into the discussion: someone will want to start a debate about whether numbers exist! Is 4 a social construct, invented by men just to annoy feminists?
How do you know they add more noise or jitter?And due to there are no real distinction between "digital" and "analog" components or signals - I use "analog" components in "digital" circuits and "digital" components in "analog" circuits.
Simply because sometimes the available "digital" components creates more noise, adds more jitter and are slower (rise and fall times) than an alternative "analog" component..
As an example - a "digital" inverter can be used as a "analog" amplifier as the "digital" inverter are made up from one P and one N channel FET etc..
But please explain how there is no distinction between analogue and digital signals...
Audio 20-20,000Hz variable level signal, DDR memory 100MHz clock square wave!!!
I would presume you would lay out a digital board with star grounding instead of a ground plane.
Erin, I am impressed by your square waves, please explain how and why digital signals tend to end up with rouned edges when transmitted...and while your at it why is the rise time of the signal critical in determining the harmonic content of the square wave.
That explains the most 😀
I realize the "differences" in understanding the basic concepts are monumental - and I can easily live with our "differences"
nobody can say the attitude doesnt match the so superior ultimately expensive, ultimately performing, infinitely evolved, constantly changing, never before seen here system
That's kind of a lame example IMHO (any CE transistor is an inverter). Do you have an example using, say, a 4013 or 7400?As an example - a "digital" inverter can be used as a "analog" amplifier as the "digital" inverter are made up from one P and one N channel FET etc..
yep and most DAC ICs and computer CPUs are made of transistors, so what? not all will do a suitable job of amplifying audio to a good quality at lower frequencies with low distortion.
Who knows, they may be right. When I left the office on Friday, the precision CNC machines were making 256 toothed gears. No-one changed the programming and the file is the same, but now the gears all have 255 or 257 teeth. The operators are telling me that this is normal, 256 is just an average value, this sort of thing happens all the time when they use disk drives instead of thumb drives.
don't be frustrated, check gear backlash of your CNC, might be the gears your CNC machine's problem
what I'm talking about has nothing related with this CNC "error"
That usually does not need a translation, but here is an explanation for you:
René Magritte - Wikipedia, the free encyclopedia
- Digital Source
- DIY hifi source
