Can anyone tell me if the center post in tubes such as the 7N7 is attached to anything or is it just for locking the tube in? Reason I ask is that when you look at the underside of the loctal socket the center post hole has a tab with a mounting hole for say a wore to be soldered to.
Thx
Thx
Normally it will be grounded to act as a shield.
Thx
So u can tie a resistor or 2 there as long as they are all expected to go to ground agreed?
Thx
