dual gang audio pots and where to find them
I had no idea these parts were so hard to find. When I built my amp, I used a single gang pot for each channel's volume control. It got to be kind of a pain tweaking the dual volume controls until both channels were equally loud. Radio Shack has a 100k dual pot but that's too high a resistance for my application. Where is a good place to get a 10k dual gang pot?
How much do you want to spend?
OEM quality:
http://www.futurlec.com/Potentiometers/POT10KADUAL.shtml
OEM quality:
I have some Mil-Spec RV4 types in stock....
1/4" single shaft not concentric ...
Steve @ Apex Jr.
steve.apexjr@prodigy.net
Steve @ Apex Jr.
You could try mouser.com part# 313-2420F-10K, it's a 24mm Alpha brand. I bought a couple of this style a little while back, seem to be pretty good construction.
Thanks for the quick response!
THank you all. That was very helpful. Since I already have a hole drilled in the chassis front panel, I thought I'd put a balance control in the hole. Anyone know how to wire one of these and can I use one of my original pots to do it?
Dual gang on/off?
Does anyone know where I could get a small dual gang on/off switch so I can turn my stereo circuit on at low level nd then keep turning to raise the volume?
if you look in Bourns or Vishay spec sheet you can find a letter for the type with switch function
you can choose a linear pot and mount a resistor from the variable pin to ground(1/5-1/10 of the pot value)
I hear ya BUT that raises my eyebrows. I like to use the volume control as little as possible to reduce wear 'and tear' - it is mechanical, it does [usually] wear out, it will [usually] make you regret going that route sometime in the not very distant future - it has for me . If at all possible, I think it is much better to have a separate on/off switch.
This is for a project that has size restrictions, so big bulky pots and switches are not ideal.
I just want something like this:
New 500K Linear Taper Pot on Off SPST Switch 3A 125V A | eBay
but dual gang.
but dual gang.
hmm, for guitar there are some where a switch function is activated by pulling the shaft out
but reminds me...you need a spec sheet to make sure its fit for mains voltage, and not just a signal switch
may be just for small signal
you can get small and neat push bottom switches for mains voltage
or simply just mount the switch on back panel
thats where the mains voltage comes in anyway
this trash box I found already had both a switch and cable plug ...cost free 😀
Thanks guys, but I think I actually found just what I was looking for in another post in this forum.
Here's what I bought. I know its tiny, but my circuit is actually for a portable mp3 player boombox.
RK0971221Z11 ALPS | Mouser
- Design & Build
- Parts
- Dual gang audio pots and where to find them
