No for the simple reason that I haven't a clue how to select the 'properly designed solid state circuit' in order to make the comparison - not for want of asking.
As I said, 'forget the whole "properly designed" part'.
So, can you show me any factual evidence of tubes sounding objectively better than a solid state circuit?
When you're ready for a 'proper' scientific dialog about high-end design then let me know![]()
I assume your definition of "proper" here is "in whatever terms abraxalito deems suitable".
I am asking for some simple, factual evidence. You are using a lot of space and energy in order to try to weasel yourself out of that question.
A solid state circuit chosen at random?
Its commendable that you're stating your assumptions. However no, this time its wrong. I meant a discussion where you check your self-importance at the door. Would that be too much to ask?
I noticed no well-formed question. Anyone can claim what they say is a question...
Ah, yes, no attempt to answer. Are you honestly claiming you don't understand the question, or are you just trying to avoid answering it?
Its commendable that you're stating your assumptions. However no, this time its wrong. I meant a discussion where you check your self-importance at the door. Would that be too much to ask?![]()
Please define self-importance in a false-able way.
I noticed no well-formed question. Anyone can claim what they say is a question...![]()
Just like anyone can claim not to understand a question. I think you *have* actually answered the question (by going to extreme lengths to avoid having to answer it), so let's move on...
There's a reason for that - if you digested the last line of my last post you'll have a clue what that reason is.
False premise. I understand in vague terms what you're asking but there's not enough detail to pin it down for an answer to apply. That's fine - you're not obliged to provide detail, just if you want a reasonable discussion then it will have to be forthcoming.
Please define self-importance in a false-able way.![]()
Ego. Personality stuff - science is ego-free right? Not sure if those count as falsifiable, but perhaps they do clarify?
<snipped irrelevance>
OK, let's try with a simple one then - can you show me any factual evidence of a tube amplifier sounding better than a solid state amplifier that has been designed for the same purpose and is in the same price category?
Never has, never will be...
The real question is if the ego (or lack of it) matters. Does it alter the facts?
How about arguing facts rather than personality traits?
Good morning from Finland!
Well that's right. And since there are clear differences between solid state devices, these colorationd are clearly audible for all of us.
There is no feedback loop that could correct all the changes that components make for the signal, and remove the distortion that was generatd by components.
You totally missed the point on this. Where in this text it says that this "warmth" is negative term? Do you think that second-order harmonic distortion is bad for the sound, compared to other harmonics?
And opposite of the warmth is not "accuracy", it "coldness" (or correct me if I'm wrong with my English..;=) IMO, this warmth is just neautrality and accuracy, when listening for acoustic instruments.
The point was the part "source of this is by no means agreed on"; meaning that you just can not measure the device, and by the measurement tell if is sounds good or nor.
And I couldn't care less. So now you must be saying that I'm driving wrong??![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
You really still don't get the point, no matter how many times it is repeated. Let's put this in capitals; YOU CANNOT MEASURE THE SOUND QUALITY WITH ANY KNOWN MEASUREMENT! Or if you really can, could please share this earth shaking measurement method with us?
This discussion was started by your DSP- recommendation. Do you Julf actually really think that DSP can change the solid state device so that is sounds like the tube one? This DSP should be able clean the signal of all colorations that the SS device added to the signal, so it should be able to output 100% "original" signal with no any colorations at all. Wow, quite a DSP...!
And about the ABX; I think it is quite useless to compare two more or less coloured devices to each other, and try to guess which one is more "neutral". You can surely hear the they are "different", and you can hear that which one is "better" for your ears and taste, but you can't tell anything about the neutrality or accuracy. For me, only comparison point is the live instrument, and how accuratly it's tonality is presented. And as I said, this is quite often the hard part.
So Julf, just get the idea of our tastes & preferences; how often do you go to live acoustic concerts, how often do you listen for live instruments or singing? What kind of tube devices & setups have you heard, to compare them for the live sessions?
.No, the question is if the minuscule addition is audible or not
While, on an individual level, "every transistor, every diode", and even every resistor has some minuscule contribution to the signal, the feedback loop in a typical amplifier circuit actually corrects and nulls out that contribution.
Thanks - I think you just argued my case.The reason a lot of people like tube sound is "due to the non-linear clipping that occurs with tube amps, or due to the higher levels of second-order harmonic distortion, common in single-ended designs resulting from the characteristics of the tube interacting with the inductance of the output transformer". As in tubes causing a "pleasing" (rather than "accurate") sound.
Yes. To me that is one of the most important criteria for a car.
Agree. Can you tell me one of the hundreds of criteria where tubes measure better than semiconductors?
Still not enough detail - what in particular counts as 'factual evidence'? I have done no experiments with tube amps myself.
Never has, never will be...![]()
I agree in practice it hasn't been. But that's no reason not to aim for more efficient science.
Depends what you mean by 'facts'. Certainly ego can get in the way simple observation, yes. People tend to see what they want to see. Hear what they want to hear. So yes, its most certainly an issue.
Strawman.
Greetings to you from China.
I have an idea on this - what's great about tubes is their linearity in the presence of low-level HF interference. So if you were to measure IMD performance say -40dB down from clipping with a multitone signal that also included some even lower level (say -60dB) signals out of band, I believe you'd measure a difference between a tube circuit and a bipolar long-tailed pair.
That's my suggestion for a starting point![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hyvää huomenta!
Just because there are measurable differences doesn't in any way imply that the differences are audible.
Why not? Familiar with control theory?
And where does it say it is a positive term?
I think significant amounts of distortion is bad, whatever harmonic you are looking at.
And since when has "warmth" meant "accuracy" in English (my third language)?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
In many cases you can. There are a lot of audible distortions that are easily measurable.
No, you are probably just one of those annoying guys who take forever to get through a green light, leaving everyone behind him to wait for the next green![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Shouting doesn't change the fact that a lot of the measurements (requency response, distortion etc.) do correspond to perceived sound quality.
Yes.
Amplifier modeling - Wikipedia, the free encyclopedia
Virtual Valve Amplifier - Wikipedia, the free encyclopedia
"No audible coloration" is very different from "no coloration at all".
About once a month. Amsterdam is fortunately blessed with a very active circuit.
Would be quite an effort to list all the equipment I have worked with over the years - but it does include things like the Voimaradio tube amps designed by renowned Finnish guru Tapio M Köykkä...![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
And I couldn't care less. So now you must be saying that I'm driving wrong??![]()
Yes.
Wikipedia is always a good starting point.
"The usual test for a statement of fact is verifiability, that is whether it can be proven to correspond to experience. Standard reference works are often used to check facts. Scientific facts are verified by repeatable experiments."
So why are we having this discussion then?
Ego is definitely a factor in claims. So before we elevate claims to the status of acknowledged facts, we verify them, to filter out, among other things, the effects of the ego.
How did a discussion about DACs turn into a debate on epistemology?
Do you mean that you can't hear any differences between solid state devices at all? If you can hear them, it means that they add different kind of coloration to the signal. Do you think that DSP can remove or even alterate that coloration?
Because, if all coloration could be removed, we would have a 100% perfect amplifier that does not change the input signal at all. And after that culd be done, we could not hear any differences between the amplifiers.
In my own listening experience with dozens of solid state and tube devices, that's what I'm trying to say all the time!! I don't care about theories and technologies, sound is all that matters. It seems that you like to measure your devices, and I like to listen them. I'm just OK with your approach, but why you can't be with mine?
I have read one university thesis were this was in fact approved to be wrong. Unfortunately it is in Finnish so it wont help you guys. I tried to search for a brief explanation in English from internet, this is what I found from Stereophile:
"It's the overtones, or even-order harmonics, that give a musical instrument—or a voice—its tonal color. So if a tube amp (or preamp) adds a bit more even-order distortion, it matters very little. It won't scrape against the ear. Solid-state amps, on the other hand, tend to produce odd-order harmonic distortion, which, even in scarcely quantifiable quantities, will scrape against the ear—even more than the jagged bits and pieces of digital sound."
McIntosh Laboratories MC275 power amplifier | Stereophile.com.
And since when has "warmth" meant "accuracy" in English (my third language)?![]()
Well, maybe since the same day that "coldness" means accuracy ;=) Once again, a matter of taste.
Yes, you can see from a measurement if something is wrong with this one measured variable. But you can't see anything if all other variables affecting the sound are OK or not.
Yes.
So do you mean that you change your Creek to sound like nCore with your DSP? Why won't you?
Would be quite an effort to list all the equipment I have worked with over the years - but it does include things like the Voimaradio tube amps designed by renowned Finnish guru Tapio M Köykkä...![]()
Respect! :=)
I wouldn't say "at all", but no, I can not reliably tell any differences between reasonably modern solid state hi-fi amplifiers in a double-blind ABX test. I thought I could tell differences until I actually tried it in properly controlled circumstances.
Probably because I am an engineer - I like to understand *why* things sound (or don't, as the case might be) in a specific way, and how to improve it.
I have no problem reading Finnish
While Stereophile isn't the most scientifically accurate source, I totally agree with the first part - it is usually the added even-order harmonics that give tube amps the "warm" and "pleasant" sound - but adding harmonics is not accurate. On the second point - modern semiconductor amps have so little distortion (unless driven to clipping) that it is inaudible.
Why would I? Both sound much more neutral than my speakers will ever be capable of. The nc400 just has much better current drive capability and efficiency. No way I would do a 4-way active 1.2 kW system with linear amps.
I hold that tube amps are the more accurate in the mid-range so I don't believe in 'tube warmth' rather 'SS cold'
It depends how you measure distortion. Presumably you're talking THD in which case I agree. But THD isn't the dominant distortion when listening to music - IMD is. So the fact (undisputed by me) that the THD of most modern SS amps is inaudible is irrelevant in practice. Do you have any multitone IMD measurements for the tube amps you've played with?
Not entirely irrelevant. For IMD to occur, you have to have a nonlinear system. Nonlinearity also produces harmonic distortion, so there is a correlation between the two. In any case, both are easy to measure.
Anyway, this really seems to have turned into Yet Another Tubes vs Solid State Debate - and if that issue hasn't been resolved in the last 40 years, it probably won't be resolved this week either. All I can do is repeat my original advice to the OP - go for a reasonably-priced pure-semiconductor DAC that is easy to upgrade as technology changes, and add a tube buffer stage to get the tube sound. Yes, in that solution there might be 2 or 3 more semiconductors in the path compared to a minimalist "tube DAC", but will you really hear the difference between 100 semiconductors and 103 semiconductors in the total audio path (probably more like 1000 vs 1003)?
I assume you are referring to re-entrant distortion. This is not caused by time delay. It is simply a matter of algebra. No delay needed. In fact, no feedback needed either. You just need to ensure that a non-linear circuit element 'sees' its own output. Wiring a non-linear component in series with a linear component can be sufficient to see this distortion. Interestingly, the only people who worry about re-entrant distortion are generally the people who don't really understand distortion and/or feedback.stephensank said:Feedback does NOT correct colorations in actual practice, a more often feedback corrects most, but then adds distortion of it's own, due to the time delay involved.
Someone quoted from Wikipedia, which says something like 2nd-order distortion comes from a valve interacting with the inductance of the output transformer. Not true. Don't rely on Wikipedia for audio engineering. 2nd-order comes from the valve itself (and 3rd order, and 4th order etc.).
In the current context "properly designed" could mean not sending the raw output of a DAC chip straight into a circuit (opamp?) which cannot cope with the sharp pulse edges. That requires either a very fast opamp, or a diplexer circuit to divert the HF energy to a resistor. "Properly designed" could also mean not grossly violating the output voltage swing spec of the DAC chip, as almost all 'passive I/V' circuits do; the result is a severe testing of the linearity properties of the chip current sources. 'Passive I/V' 'designers' sometimes seem never to have read (or understood) the chip datasheet.
When I speak of bad effects of feedback, I refer primarily to what Nelson Pass was addressing in his "stasis" amp designs. Distortion of non-repetitive waveforms caused by feeding back signal to the differential input of a circuit that has been delayed by time it takes the original signal to get through the circuit. The simpler & physically shorter the signal path, the shorter this delay will be, but it nevertheless exists. Feedback works really superbly on waveforms we can readily measure, but it can work very badly on actual music. I don't advocate that all feedback is bad, just that it needs to be used far more carefully & sparingly in audio circuits than is generally done.
As for passive i/v and dac chips, as an example, published and my own measurements on the PCM63 verify what I hear, that this chip copes extremely well with a 100ohm passive i/v load. My own measurements & ears also tell me that the PCM1702 & PCM1704 cope quite well with 10 and 20ohms. Likewise, I see & hear absolutely no problems with a 6DJ8 or a 2SK170 jfet coping with the pulse edges from these chips.
Mr. Julf:
"I wouldn't say "at all", but no, I can not reliably tell any differences between reasonably modern solid state hi-fi amplifiers in a double-blind ABX test. I thought I could tell differences until I actually tried it in properly controlled circumstances."
Really? If this is true, I must further doubt your opinions. But let me give you some hope that I am not prejudiced in the opposite direction of that which I have accused you of being. I think it damn near impossible to design, e.g., a preamplifier that has an entirely tube signal path which I could call "accurate" in the best sense of that word, which I like to qualify by saying "accurately musical". As I said previously, tubes are best used for voltage gain & transistors best used for current gain. Any preamp or power amp needs to do both types of gain in a linear fashion to achieve accurate sound. A preamp is primarily for voltage gain, but it's final stage needs substantial current to drive the line & the amp input, and the amp's final stage needs a lot of current gain to drive the speaker. Tubes just don't do this job extremely well compared to ss devices. But tubes are more capable of linear voltage gain, so I am very strongly an advocate of hybrid designs, where one uses tube purely for voltage gain(to the extent possible, which is not always completely) and ss devices purely for current gain(pretty well always possible). It seems to me that every time I hear anyone complain about tube sound, when queried, I find that their negative opinions have been based on tube gear that has used tubes to also do current gain, such as an all tube power amp, or a *dac that uses tube for final output*, like the stock Monarchy. Had I not added a high-current ss current amp after the Monarchy's tube stage, it would not have a prayer of competing with the other dacs it is now exceeding.
Not to say that there is no such thing as a great all-tube preamp or amp, just that I have never heard one that I could call "accurately musical". However, I have heard tube gear that has sounded so utterly gorgeous that I did not give a damn about accuracy. Anyone who has heard a Marantz 8B with UK Genalex KT77 or Holland Amperex EL34 output tubes installed, on a great pair of adequately efficient speakers(in my case Yamaha NS2000 w/upgraded internals) would have to agree. The sound is absolutely not accurate, but it made me feel like I had died & gone to audio heaven.
Mr. Julf:
As I said, time delay is irrelevant in audio amplifiers. It becomes an issue for higher HF or VHF amplifiers, at 1000 or 10000 times the frequency of audio. People sometimes confuse low pass filtering with time delay; I assume that is the case here.When I speak of bad effects of feedback, I refer primarily to what Nelson Pass was addressing in his "stasis" amp designs. Distortion of non-repetitive waveforms caused by feeding back signal to the differential input of a circuit that has been delayed by time it takes the original signal to get through the circuit. The simpler & physically shorter the signal path, the shorter this delay will be, but it nevertheless exists. Feedback works really superbly on waveforms we can readily measure, but it can work very badly on actual music. I don't advocate that all feedback is bad, just that it needs to be used far more carefully & sparingly in audio circuits than is generally done.
I do agree that feedback has to be used more carefully than some do; in some cases this might mean using more feedback, not less.
As you should - doubting is good, and verifying facts is even better.
Have you ever "tested" your golden ears in proper, controlled, double-blind ABX situations?
I do believe that there has been numerous occasions mentioned, where in blind tests most people who tried could not distiguish between solid state amps. I have tried at home with my amps and could not distinguish between them. Not one of the chosen ones who can hear a wasp F*** in a thunderstorm, but at least it allows me to enjoys my systems, one valve one solid state.....
On design I find it strange that there is so much argument, you cant design without measurements, certanly you could not design a product by listening alone. And by the same token you have to test what you design and part of the testing (assesment) is listening.
I just wish I could be so sure of my delusions that I could believe what I hear, but I dont trust my brain, so I always have a bit of skeptism regarding what I hear and whether I percieve changes, so cant be so arrogant in my views regarding listening tests. These are hard enough when only yourself is involved (self delusion) when there are numerous people involved...
Absolutely. You design by numbers, and verify the result both by measurements and listening.
Indeed. I used to believe I could hear all sort of system differences - until I actually verified it, and realized how powerful an effect perceptual bias can be.
- Digital Line Level
- About tube DACs?
