Esperado, please, I am not beginer at this.
It seems you are in some bad mood, those last times, not accepting or considering any other's inputs (witch do not reduce your and was not criticism). don't you read: "with big nuances on the 'severly'" witch was just provocative, indeed, and reason too for my "I must admit' ?
You are the one witch wrote:"I would not try this, since CFB resistors paralleled with cap usually
cause immediate oscillations". Witch is not true in all CFB amps and not friendly while i just wrote the contrary.
Well, i will not bore you any more on this thread and your others, my two cents were in order to help and experienced, with a friendly intention.
I hope-you the best for your future designs.
but my output emitter resistor are How lethal they are ?
Using wire-wound resistances at the source of my power FETs (not the same amp than your) brings oscillations:
I was obliged to use paralleled metal film resistances instead, to reach the same power rating without the inductance problem. Problem ended. Too, and it is just a personal opinion, film resistors brings a more 'fluent' sound, i find carbon resistances to sound a little granular. And they are noisy.
I take care too of a big margin in the power and quality of the feedback resistances, as the resistance distortion is here the most important and increase with temperature.
