Help: Interstage Transformer for 7788 (E810F) Tube in Triode ?
I want to use the 7788 in triode to drive a 45.
The plate voltage of the 45 is ~250V.
I plan to use this same voltage source for the 7788.
7788 will draws 15mA.
I want to use interstage transformer.
Does anyone know what would be a good impedance and ratio for the interstage to couple the 7788 triode ?
Thank you.
What do you think would be a good bias point for the 7788 to drive a 45 tube ?
I prefer ~250V because I can use the same voltage source as the 45.
But I would build a separate power supply if different voltage is better.
I'm using 320V B+ on the 45 at 40mA. I get 5% distortion at 5W, and it still sounds relatively clean at this level.
I've used 5842 and D3a to drive the 45, using a variant of George's TSE circuit. The 7788 is a drop-in replacement for the D3a, but I've never tried the 7788 myself as I don't own this tube. Anyway, I have a CCS which drops the voltage down from 320V to 130-200V (adjustable). I run at 180V. High transconductance tubes have a lot of variation so adjustable bias is very useful to install.
Which do you prefer, D3a or 7788?
I use D3a, E280F (triode mode, mostly 10mA CCS load) as amplifier's first tube. I have about prefer of them Siemens E280F. Best holographic space, microdynamics and clarity -IMHO-.
I tried 7788 (I have four Philips SQ, and two Valvo pairs, best of them Valvo -green print Philips Herleen made-), but not of my cup of tea. It seems a bit boring.
What do you think would be good bias voltage and current for the D3a to drive a 45 tube ?
Try the 10mA to 25mA range. It sounds a little different, so you have to decide for yourself what you like. It tests lower distortion at higher bias currents, but the sound can get a little edgy (excellent realism, but more fatiguing after a period).
I have capacitor coupling, with interstage coupling it will sound different. Interstage sounds sweeter, has more harmonics.
I used both D3a and 7788. They are great for power tube which need below 40-50V gain. IT 5k:5K is so good.
In your case, Pout 5W is quite impressive 🙂 . how much is Pa of tube 45 ?
