Hi all friend here!.
I want to know if any of you have the following tube models or know where can I find them. In the Norman Kohen they aren't and Google didn't give any answer.
They are:
ECF801 - EC900 - EF184 - EF183
Many Thanks to all.
Best Regards.
They are:
Many Thanks to all.
Best Regards.
tubemodel_3.01_win.zip
EF184 would be 6EJ7 in the above zip.
EC900/6HA5
* 6HA5 LTSpice model
* Koren model (5 parameters): mean fit error 1.27016mA
* Traced by Wayne Clay on 9/6/07 using Curve Captor v0.9
* from GE datasheet
.subckt 6HA5 P G K
Bp P K I=
+ (0.0007088605362m)*uramp(V(P,K)*ln(1.0+exp((0.01050076569)+
+ (0.01050076569)*(16410.47684)*V(G,K)/sqrt((7.516756983k)+
+ (V(P,K))**2)))/(0.01050076569))**(1.177167506)
Cgp G P 0.56p ; 0.2p added
Cgk G K 5p ; 0.7p added
Cpk P K 3.1p ; 0.2p added
.ends 6HA5
EC900/6HA5
* from GE datasheet
.subckt 6HA5 P G K
Bp P K I=
.ends 6HA5
Here's more 6ha5 models:
http://www.diyaudio.com/forums/tubes-valves/81978-looking-spice-model-6ha5-similar-tubes.html
6HM5
Code:
* 6HM5_k8 LTSpice model
.subckt 6HM5_k8 P G K
Bp P K I=(0.001154846006m)*uramp(V(P,K)*ln(1.0+(-0.0008415623491)+exp((0.05049252985)+(0.05049252985)*((5446.000628)+(178663.8165m)*V(G,K))*V(G,K)/sqrt((-0.2140185688)**2+(V(P,K)-(-162.56846))**2)))/(0.05049252985))**(1.356125726)
.ends 6HM5_k8
Code:
* 6HM5 LTSpice model
* Koren model (5 parameters): mean fit error 1.20978mA
* Traced by Wayne Clay on 9/9-07 using Curve Captor v0.9
* from GE datasheet
.subckt 6HM5-k5 P G K
Bp P K I=
+ (0.0005835219273m)*uramp(V(P,K)*ln(1.0+exp((0.005618954395)+
+ (0.005618954395)*(31322.45425)*V(G,K)/sqrt((8.885069314k)+
+ (V(P,K))**2)))/(0.005618954395))**(1.124019828)
Cgp G P 0.54p ; 0.2p added
Cgk G K 5.2p ; 0.7p added
Cpk P K 3.2p ; 0.2p added
.ends 6HM5-k5
Ok, thanks again!!. Do you know any model for pentagrid tubes? (for make a audio compressor/expander) such as a 6BE6,6CS6, ECH83? Hot to manage two input signals? And for a 6BN6??? (very difficult I believe)
I don't have any good ones for those tubes. Here's 6BE6 and 6CS6 models that use an op-amp symbol. To use 3f4 in LTSpice you may have to change ^ to **.
Code:
*Vacuum Tube pentagrid (sharp cutoff)
.SUBCKT X6CS6close G 3 S K A
*model written to use op-amp symbol +in=g1,-in=g3, +supply=g2g4, -supply=kg5, out=plate
*work in progress, not final
* Calculate contribution to cathode current
*the number at the right end determines sharpness of knee
Bat at 0 V=0.636*ATAN(V(A,K)/8)
*the URAMP(V(S,K)/# mostly determines peak plate current, grid line spacing nearly constant
*the number at the right end determines slope of grid lines (plate resistance)
Bgs gs 0 V=URAMP(V(S,K)*1.6164+V(G,K)*24.75+V(A,K)/9000)
Bgss gss 0 V=URAMP(V(S,K)*0.0005+V(3,K)*0.0075+V(A,K)/9000)
*the exponent sets the linearity of grid line spacing, and big impact on peak plate currrent
Bgs2 gs2 0 V=V(gs)^1.5
Bgs3 gs3 0 V=V(gss)^1.5
Bcath cc 0 V=V(gs2)*V(at)
Ban an 0 V=V(gs2)*V(at)*(V(gs3))
* Calculate anode current, grid line spacing adjust and peak plate current
Ba A K I=0.345E-3*V(an)
* Calculate screen current
Bscrn sc 0 V=V(gs2)*(1.0-V(at))
Bs S K I=(URAMP(0.64E-3*V(sc)-(1.45E-3*(V(an)))))*0.29*(V(at))
* Grid current (approximation - does not model low va/vs)
Bg G K I=(URAMP(V(G,K)+1)^1.5)*50E-6
* Capacitances
Cg1 G K 5.5p
Cak A K 7.5p
Cg3 3 S 7p
Cg1g3 G 3 0.36p
Cg1a G A 0.07p
.ENDS X6CS6close
Code:
*Vacuum Tube pentagrid (g3 remote cutoff)
.SUBCKT X6BE6close G 3 S K A
Bgss gss 0 V=URAMP(V(S,K)*0.0005+V(3,K)*0.0045+V(A,K)/9000)
Bgs3 gs3 0 V=V(gss)^2.7
Ba A K I=0.345E-2*V(an)
Bs S K I=(URAMP(2.34E-4*V(sc)-(0.95E-2*(V(an)))))*0.29*(V(at))
* Capacitances
Cg1 G K 3p
Cak A K 8p
Cg3 3 S 7p
Cg1g3 G 3 0.15p
Cg1a G A 0.1p
.ENDS X6BE6close
The circuit hasn't been optimized to use a 6HM5. I just dropped it in to show that the 6HM5 model I posted works with no errors. 🙂
Hi again. I found that this guy has made his own tube models using a point to point curve digitalizing, and has a great job and explained it. But I could't find why in some instances he used a "dummy resistor" in the text and how to estimate or calculate it and for what did he use it. Can somebody explain me this?
Best regards.
Best regards.
Best regards.
You can send him a private message to see if he would answer your question. But looking at the model, I think the dummy resistors are used for either source or load impedance, most likely for SPICE calculation convergence purpose.
Did anyone get anything in the tubemodel_3.01_win.zip to work in LTSpice? I tried the 6ej7 pentode connection but it did not work.
Some don't work but most do, is my experience. I don't use LTSpice but SIMetrix, here is the Ia vs Vs plot for the 6EJ7 using Ayumi's model, matches up well with the datasheet:
The 6EJ7 model as well as all of the others that I've tried in LTSpice seem to work OK. What error message are you getting? Have you changed all instances of ^ in the file to ** ?
That worked, thanks! I read that earlier, just had trouble following the thread I guess. FYI, what do 3f4 and 3f5 refer to?
Hi
I am a newbie of TINA-TI. I'm trying to locate the spice model for EC86 / EC88 / Ec8010, but no result on the web. Please give a hand.
cheers
Coffin
cheers
Coffin
Thanks a lot!
But when used the macro wizard to import EC86.mod, TINA-TI told me line 11 "V" is invalid function......
I'll try other models to see the result.
cheers
Coffin
cheers
Coffin
- Design & Build
- Software Tools
- LTSpice tube models
