VSSA Lateral MosFet Amplifier
These capacitors form feedback AC ground, without them amplifier is not working properly. Two in parallel to cover bandwidth currents in low Z. ;)
So, you have a current source for DC only ?
Do not believe that paralleling film and electrolytic caps reduce the Z at HF, it is exactly the opposite.
They make a resonant circuit with the inductance of the electrolytic situated inside the bandwidth of the amp. One of the reason some found SSA was sounding better without the film.
And, may-be, why you have this hard to dump ringing with capacitive load ?
No it handles every possible micro current mudulations, the ones resistor cannot at least to such low levels. Tested. ;)
Capacitor on output leads is sort of a short circuit linearly going down to zero with frequency rising. Since squares are row of harmonic structure, capacitor's impedance slowly eliminates high order harmonics and the result is distorted squares. Perfectly normal plot result. :up:
Hi LC,
First try out for 1.4 version. The board size is 72x72mm
VSSA 1.4 MosFet Amplifier PCB
VSSA 1.4 PCB final version. Miller capacitors, offset and bias setting resistors on the top, to be easy accessible and tuned to the exact value. No trimmers for no-compromise long term reliability. Output RC filter splitted in to two ways to have better power dissipation since SMDs are used.
Have fun. :cheers:
Have fun. :cheers:
What value have you use than?
Marc
