Is there the possibility to have a "clean" usb output in order to avoid galvanic isolators or stuff like this when using a usb dac?
This board design for output i2s and spdif only. Seprating DA module may get better analogue. I change the layout to ver1.1 adding one pic-e and pic for testing. It is still testing. If it is good and stable I will sale it for sure, but not too much 1 manufacrtue batch 0.5k pices.
Eric
Eric
Hi
I am interested to know more about the board.
You can hook up a spdif/ i2s enabled dac to the board to get analogue out to an amp ?
Are there being tested now ?
ARe you offering a group buy or for for sale ?
cheers
kp93300
Eric
Hi,Is there the possibility to have a "clean" usb output in order to avoid galvanic isolators or stuff like this when using a usb dac?
It is not esay get "clean USB", Cause noise leak by GND awlays, and it is almost impossible for me to isolate power supply and GND of south_bridge from other chip . But I have idependent power supply and GND for IS2 and SPDIF chip on this board.
This board may use USB DAC if OS can drive it.
regards,
Eric
Is it a double sided placement boards?
Yes, It is double side. I put capacitor, inductor, XO in the other side for EMI issue.
Eric
Indeed ! Did you make some progress Castleric ?fascinating project - subscribed!
Am interested in this one. Is the project still on ? What are the specs ? What CPU have you settled on ?
Hope it will have the best specs to support 32bit, 384khz and also DSD.
I suggest you leave out video on the board, or design it so that it can be entirely switched off using jumpers or switches, so that when setting up is done, it can be switched off
PCIe and PCI is good since it allows some flexibility experiment.
Socketed CPU will allow upgrade to higher speeds, if user decide to experiment on room correction etc. See link below for a very highly regarded Room and Speaker correction software
http://www.computeraudiophile.com/c...-loudspeaker-correction-software-walkthrough/
New Breed of ultra low noise regulators
See links below for a comparison of ultra low noise regulators
New Breed of Ultra Low Noise Regulators | H i F i D U I N O
Excluding SW regulator is what I want to do ,too. For chip stage power supply, There are more than 10 rails need be regulated by PMIC on broad and need manage on/off sequence. There are few SW regulator inside PMIC for control purpose what liean regulator can not do. It is possible using more than 10 linear regulators replace the one power managment IC but that may cause stable problem, so I give up doing that finally. I think the power supply structure of this broard is the fewest in using SW regulator. And the source of sw regulator is leaner power.
Please see link below. There are lots of useful design information. Also a discussion on how best to implement I2S to keep jitter low, and mistakes that designers usually make.
http://www.diyaudio.com/forums/digi...i2s-digital-signal-path-line-resistors-5.html
castleeric,
Why don't you join resources with the guys below. kyrill and CAD can probably help with development
Dedicated Audiophile Motherboard development | Computer Audio | Forum | JPLAY - hi-end audio player for Windows
Why not go the whole hog? | Computer Audio | Forum | JPLAY - hi-end audio player for Windows
If the design is not set in stone yet, let us discuss it and put our minds together and re-specs so that it can cover a multitude of applications and flexibility. Let's put our heads together to specs the ultimate audio motherboard.
castleeric,
Marce seems to be the expert here on pcb routing, see below
http://www.diyaudio.com/forums/digi...i2s-digital-signal-path-line-resistors-6.html
No problem, I layout PCBs every day of the week and have done for over 25 years now, and do a lot of high speed, SMPS and hi reliability PCB layouts. I have always got this info to hand, not only for use at work, but for a PCB forum where we get asked the same questions repeatably.
- PC Based
- Music Main board for diyer
