Hi everyone,
I have a old unbranded amp it says bma500 on the front and have google it but no luck. Its 500 watts 250 a side the problem im having is sourcing two of the mosfet chips I have already got the buz900p but can not find two mlp120p chips does any one know where I can get one from or even know the equivilant match.
All help is great.
All help is great.
The BUZ905p is the complementary for the BUZ900p and should be easier to find.
Made I believe by Magnatec also sold by RS Components
You are not looking for chips, but for transistors. BUZ900 is a power MOSFET.
Check whether you read the print on the other one right. Could it be MLP1N06? A current limited power MOSFET?
Hi pacificblue yeah power mosfet well in the right channel there is two buz900p transistors and two mlp120p I checked again tonight and that is certainly the one I need the amps quite old and has been extreamly reliable so would love to get it revived.
I picked up the two buz900p easily its just the other two mlp120p I can not find I googled it but not a lot of info was there.
I was wondering if there is a equivilent for it that I can use with the buz pair. I got the buz from cpc.
Thank you both for the replies
Thanks for the replies I have already got two buz900p but I checked and it is certainly a mlp120p this is for the right channel of the amp.
The left is fine and works sweet. The amp is probably 12-15 years old but is good.
you need two BUZ905p as I said before
Thank you so much bone will get two in fingers crossed she may live again.
Ill keep you posted on the outcome.
Thanks again guys for the advice.
- Chip Amps
- Hi guys need a little help
