Trinaural decoding equations for 3 speaker stereo matrix ?
What's the next step for the experiment? A FRS8 at center too or will you try e.g the Nathan there and see if the tonality is a problem?
I really like nearfield bass. Not having to worry so much about neighbors is relaxing, and I also think that the lower overall bass in the room makes things sound better (less boomy) from another room. Do you add a delay or not worry about it?
Yes, those are FRS8's but I got it to "work" with Behringer P2031A's and B200's too. Very different speaker concepts. They simply differed in tonality but not in spatial properties. The important part is level, timing and spectrum of the reflections.
The near field subs are crossed in at 150Hz for the FRS8's.
Adding a FRS8 center is next. It's already in use for surround playback.
I'm currently revisiting Gerzon's Trifield paper from 1991 ("Optimal Reproduction Matrices for Multispeaker Stereo").
Near field bass is fantastic. A high cut-off adds envelopment. Stereo bass finally might make sense in a small room. Needs to be tested though.
To answer your question, yes I did add delay to the subs.
Also please try the side wall setup I've shown. There's something "special" about this.
I've had my Nathan's set up in a standard ±30° stereo triangle away from the walls, with a 45° toe-in. The loud contralateral reflection had a detrimental effect on imaging. With the speakers directly at the wall, the problem is completely gone. The resulting reflection pattern seems to aid reproduction (spaciousness and depth).
The contralateral reflection is indeed a detrimental one in my experience. Perhaps such a wide setup compensates for the reduced channel separation with a summed centre?
Anyway, I need to build me an extra speaker first 😀
Why not simple passive matrix with coefficient 0.5 for starters ?
Gerzon had so many theories it will take a life time to try them all..
- Elias
Wrote a little script for Reaper. The matrix factor can be varied with a slider:
Code:
desc: 2to3
slider1:0.5<-0,1,0.05>Matrix Factor (0-1)
@slider
matrix_factor = slider1;
@sample
l_in = spl0; r_in = spl1;
//create MS from Left/Right
m = 0.7071*(l_in+r_in);
s = 0.7071*(l_in-r_in);
//Re-matrix to Left/Right
l_out = 0.7071*((m*matrix_factor)+s);
r_out = 0.7071*((m*matrix_factor)-s);
//output
spl0=l_out; // Left
spl1=r_out; // Right
spl2=m*matrix_factor; // Center
Here's the schematic:
attachment.php
Reaper code for "Optimum Linear-Matrix" based on Miles:
Code:
desc: 2to3 //based on Miles http://milestech.com/aesimpre.htm
@slider
@sample
//Optimum Linear-Matrix
l_out = l_in-(matrix_factor*r_in);
c_out = (1-matrix_factor)*(l_in+r_in);
r_out = r_in-(matrix_factor*l_in);
//output
spl0=l_out; // Left
spl2=c_out; // Center
More people shoud do that, really 😉 I think thy biggest hindrace of experimenting with matrix stereo is people ususally have only two speakers.
Thinking about it, it does not make much sense to me to try to reproduce images in the center with speakers placed only at the side ! The whole concept of two speaker stereo is based on compromised technology some 80 years ago. Even more incomprehensible is people accept it just like that without questioning 😱
- Elias
Have you though about dividing freq bands in Gerzonic manner, as he seemed to emphasise the importance of different hearing mechanisms along freq bands that should be taken into account in the matrix ?
Not yet. Currently listening to the "basic" versions.
Interesting observation: the center doesn't seem to be particularly stable with head movements. The stability of phantom sources don't seem to benefit from an additional speaker. Phantom sources created by only two speakers (L-C and C-R) is probably preferable.
Well, phantom center sources don't "snap" to the left or the right speaker when moving like they do with normal 2-speaker stereo. But the upmixed center speaker creates a considerable amount of ambiguity when moving.
You should try coefficient of 0.5. It maximises the separation between speakers. Did I suggest it already ? 🙄
If you are after the "snap" effect, that is the image locked into the speaker, then you will need much more directional speakers than FRS8.
On the other hand I find the "snap effect" one of the worst features (symptoms) of conventional 2 speaker stereo. It ruins the the rest of the little realism that would possibly have been there in ideal conditions 😉
- Elias
0.5 is the default in my script...
- Elias
I'm not after the "snap" effect. But in my current configuration it sounds more natural despite the spatial distortion. Pick your poison.
You know that Gerzon's techniques are based on assumptions that not everyone agrees with. See papers by Theile.
Yes I did try speakers at the side walls many years ago. All the sound was at the side and nothing much at the center. So it was not good at all. It was about the same time I understood there must be a speaker at the center to be able to generate stable center images. It also eventually lead me to my single speaker stereo SSS concept.
- Elias
Here's my implementation of a energy-preserving 3x2 matrix decoder:
Code:
desc: Energy-preserving 3x2 Matrix Decoder //based on Gerzon
slider1:35.26<-0,90,0.01>Angle parameter (0-90)
@slider
angle = slider1*0.017453;
@sample
//Energy Preservation
m_c = m*cos(angle);
m_lr = m*sin(angle);
l_out = 0.7071*(m_lr+s);
r_out = 0.7071*(m_lr-s);
c_out = 0.7071*m_c;
//output
spl0=l_out; // Left
I'm not sure if the mid signal for the center (after energy preservation) needs to be attenuated by 3dB or not. Anybody?
Schematic:
attachment.php
