Budget 300b tubes recommendations
we had one guy swapping tubes behind a curtain so we did not know which tubes we were listening too. When the KRs run, to a person, we all were shocked by how much better they sounded.
Was each tube biased to its own optimum range when switched? If not, the difference may just be due to that which can also be done without changing tube if the amp has adjustable features. :nownow:
Psvane Hi-Fi series at $300
EH 300b at €270
EH 300b Gold at €310
Shuguang 300b at $320
JJ 300b at €400
check partsconnexion, EH 300b Gold at $170/matched pair
these sound acceprtable, but the glass is a bit thin and that makes them a bit more microphonic than usual!
you've gotta be kiddin' 😱 that should be the price of a single tubes not a pair. double check it
Is there any reason that 300b's are so much more expensive than other tubes? Are they more difficult to produce? Or is it just their reputation and demand for them?
Sometimes you do get tubes that are difficult to produce. The development of what became the KT66 traces the story of how British manufacturers threw their hands up in despair at the task of making a workable beam tetrode and gave the job to the Americans, who said, "No problem."
The Chinese seem to say "no problem" to everything, and could easily flood the market with low-priced 300Bs, so the price probably reflects what the market will bear rather than manufacturing overhead.
