I've notice that just about every ported design that I've stumbled across uses one or more ports with the same tuning. I'm wondering if someone can explain why no one used multiple ports with different tunings in the same design. [For example, one 1x diameter port at 55Hz, one 3x diameter port at 27.5Hz.] I'm also struggling to find equations to model this in either Python/SciPy or Octave. Thanks.
Oh great, another opportunity to show my age ...
This has been done (there is nothing new under the sun). My apologies if I have identified the wrong speaker to have used this .... but I know it's been done and I'm quite sure it was the Hegeman model one speaker (which was an omni) which used multiple port tuning. The manufacturing of the speakers transferred to Don Morrison in Toronto, Ontario (Morrison Audio fine audio speakers and electronics.) who on his early models continued the use of multiple 1/4 wave tuned paths.
No, never heard them, can't comment on the result.
Thanks for the reference. At least someone else had the idea. Hope someone can chime in with either experience with the end product or the math to figure out whether it works or sucks.
For classic ported enclosures, the resonant frequency is set by the volume of the enclosure versus the mass/velocity of air in the port(s). Having two ports of differing sizes results in a single resonance set by the combined port sizes. For example, an enclosure with a single port 15 sq cm area will have the same resonant frequency as one with two ports, one 10 sq cm and one 5 sq cm.
In the case of quarter-wave pipes or multiple coupled enclosures, the situation is less clear cut. For example, the Weems Double Chamber Reflex has two resonant frequencies, one an octave above the other. It's very much a case of modelling your ideas and see. I recommend AkAbak as a modeller. There are several threads here which discuss how to use it.
I'm reminded of this thread from a while back (I had a little trouble finding it, I recalled it as a 1-driver-per-octave 10-way, but it's not quite that ridiculous):
http://www.diyaudio.com/forums/multi-way/169296-thinking-building-7-way-loudspeaker.html
My thoughts on making a "wider" resonance are in post #9 and there's an interesting port shown in post #17.
@DonHills: Thanks. I use a FOSS software stack, so AkAbak and the other Windows based modellers are out. I'm using gspeakers + Python/SciPy + Octave, so I need the actual equations. Thinking about it, it seems like the coupled internal sub-enclosures would be necessary. Bummer.
For classic ported enclosures, the resonant frequency is set by the volume of the enclosure versus the mass/velocity of air in the port(s). Having two ports of differing sizes results in a single resonance set by the combined port sizes. For example, an enclosure with a single port 15 sq cm area will have the same resonant frequency as one with two ports, one 10 sq cm and one 5 sq cm...
Yes. Yes? Hmmm.
That's Small's treatment from a kind of lumped parameter point of view. But Dick himself would say his derivations are approximations. Thinking about it some more, it seems to me there should be SOME difference, even if tiny.
From a practical point of view, two things come to mind:
- If the ports are different lengths/sizes, they will certainly have different internal resonances (i.e. the pipe resonance).
- With the ports at different spots in the enclosure, the acoustic excitation is at least a tiny bit difference. "Theory" says not, but as I just noted that theory is an approximation, and not actual acoustics.
- The port summation won't quite follow the simple theory as the end corrections may be different (which is a bit like the point just above).
I think multiple ports are always the same simply because it's easier to calculate.
@head_unit: That is what I was thinking. I'm a Python (language) fanatic and I've started porting gspeakers, but my understanding of the electrical and fluid dynamics aspects of speaker design are way to limited. I seriously need guidance on where to look to develop the model needed to analyze this kind of design. If anyone could point me to some relevant resources, I'd be much indebted.
Its been done, by the stupid and marketing who don't understand the physics.
Take a speaker tuned to 50Hz by one port and 25Hz by a much bigger port.
The 50Hz port depressurises the cabinet below 50Hz so the 25Hz port has
next to no effect and all it does it take up cabinet volume you could use
to tune the speaker to a somewhat overall lower alignment.
The higher tuned port prevents the lower tuned one working to any effect.
That is why, apart from clueless marketing claims/designs, you never see it.
If it worked, which it doesn't, you'd obviously see it a lot in designs.
(And be a feature in all speaker simulators, which it clearly isn't.)
rgds, sreten.
The free Basta! manual covers speaker modelling quite well and
you could add a further low tuned port to the model to see how
useless the idea is in theory and therefore in practise.
The higher tuned port "shorts" the lower tuned port.
rgds, sreten.
@sreten: I think I understand your point. I do wonder, though, I thought that multiple ports worked like parallel resistors/inductors (roughly). That is, the pressure change caused by the motion of the driver will find equalization by all available paths based on the instantaneous resistance of the paths. That would mean that with proper balancing of the diameters and lengths of the different ports, they should respond to the driver differently under different frequencies and volumes. Make sense?
Basically wrong. They are much more like series LCR's in parallel.
Consequently the highest tuned port dominates the low rolloff, by
providing the lowest impedance to ground at all low frequencies
preventing any other lower tuned port having any useful effect.
rgds, sreten.
@sreten: Thanks. Exactly what I needed to know.
Just for others who might be curious: https://en.wikipedia.org/wiki/RLC_circuit
😉Hi, Its been done, by the[...] marketing who don't [CARE ABOUT] the physics.
next to no effect...[/QUOTE]
I'd be curious to hear your comments about David Weem's design. In case you're not familiar, that's where you have 3 ports all the same size. One vents from the main chamber to outside, one from the main chamber to a second chamber, one from the second chamber to outside (was trying to find an image on the internet, but no luck).
I simply can't wrap my head around what will happen, if it really works or not. If I had more time ha ha I should build one and test it...
- Subwoofers
- Variable Port Lengths/Diameters? Like a pipe organ...
