OPA548 unity gain
I have found the problem. I had a leakage from input coupling, which separates high voltage output from tube preamp.
Thank you guys.
Thanks for nothing.
You never ever showed a tube connected to that input.
At most you commented
I want to drive unity gain power opamp with tube preamp.
which speaks about future, not that there is a tube connected there *now*.
And you didn't answer
Measure voltage to ground from + and - IN pins.
Talk about sending us on a wild chase. 🙁
That said, glad you found the problem on your own, pity Forum couldn't help you.
