Speakers For Heavy Metal ? What Matters ?
I'm no expert, GM is the man you wanna talk to, but a K15 with a pair of Altec/GPA 515 might just be what you want. Not that difficult. But speak to GM.
Deon
Well, I hope GM may express an opinion here.
Altecs and GPA's may be relatively common in the USA but they are all but unavailable in OZ and their weight makes overseas shipment unviable. I know there are Eminence based Karlson designs but the 'results unknown' factor is too great for me to take a chance with someone elses money.
Don't misunderstand, I really appreciate your idea. In a year, when I have some Karlson under the belt, I may be more willing to take a punt. I hope you are around with your suggestions then!
Kind regards,
potkettleblakk
Not up on modern Metal but I remember recordings with a lot of Ambience and dynamic compression so I'd be thinking of a system that is smooth through the midrange and dosent become shouty and stays balanced with high volume..
Just my 2 cents, Joel
I cant think of a serious metalhead who would be happy with a dome midrange and a planar. Would be good for some kinds of music, but go crank some Nile through it and see how happy it makes you.
And no, metal doesn't contain harpsicord or violins ...or keyboards.
I'd lean towards a 12"+horn 2 way or a 15"+6-8"+treble horn depending on budget and requirements myself and seriously consider going active.
Beyma has some good looking new (at least to me) drivers which are cheap here but some cost more than double on US sites.
Something like this:
http://profesional.beyma.com/ingles/pdf/15LX60V2.pdf
http://profesional.beyma.com/ingles/pdf/8P300Fe.pdf
http://profesional.beyma.com/pdf/CD10FeE.pdf
http://profesional.beyma.com/ingles/pdf/TD194.pdf
Would cost £130 + £56 + £36 + £30 =£252 +vat here in the UK (bluearan.co.uk) but
$326 + $170 + $150 + $100 = $746 (£462) (prices from usspeaker.com).
The UK prices seem a bargain, the US ones not so much. No idea what the Oz prices would be.
There seems to be quite a lot of good looking cheap drivers coming out recently from Beyma and Faital and may be others. Not sure how well the prices travel around the world though.
Up your budget - get a Nao Note - Metal music is one of the more complex genres -
you need quick bass = active crossover
need clear mid bass = dipole mid bass
I got a Nao Note - totally no regrets - clear metal music and heavy rock no distortion even at low volumes
If it is very heavy metal you needs loads of bass.
Quite often heavy metal guitarist tune down their guitars to get lower notes and get a heavier sound.
Yeah but guitars don't go that low even tuned down to C# (3 half notes down) as Black Sabbath and most doom and much death metal is. That's still only a 69.30Hz fundamental frequency. Almost no information at the fundamental anyways. Most is in harmonic distortion.
dont forget you will have phase issues at rolloff
low end roll off is no different from any other crossover point in that respect
another point is you will probably use vented BR tuning
and maybe even high Q tuning
but you know what happens when hitting it with notes below the tuning frequncy
I dont expect you would quit everything above 8000hz
even if that would make more sense
I guess it will be no surprice when I suggest a closed box design, maybe apperiodic to have some venting
