ok this one looks nice and it makes good wallpaper😉
and it,s stylish😀
I would like to know where you got the shower curtains from? I know its been a while but I am looking for something the same as this, can anyone help out?
the gold rings around the base of the tubes.
Hey, that scope looks familiar 😎
Mine has a French front and came with a Russian manual...
Too bad it died recently 😡
A Russian product, low price 😀Hey, that scope looks familiar 😎
Build this amplifier last week! The dimensions of many pre fabricated cabinets are not of my liking, so I decided to build one myself.
It's a stereo single ended EL84 design using 'schade feedback'. It's build exactly according to Aleksandar Kitic's RH84 schematic.
It uses a JJ 5U4GB rectifier and a JJ ECC81 as driver. The power transformer is wound to my specification by 'AE Europe' in Schagen, Holland.
Output transformers (AT06) are from HB Amp Design in Germany. The parts are all ordered,
except the EL84's (Haltron, made by Tungsram factory) I had those lying around... mostly the reason I build this.
It sounds great! The lower frequencies are represented very well, and the mids and highs are very detailed, great schematic.
Actually it doesn't use Schade feedback, this kind of feedback is invented by Aleksandar Kitic himself.
Mine had Cyrillic Russian front and no manual....🙂Hey, that scope looks familiar 😎
My tube love perys | perys - Jadis-JA-30_mk2012 ? rajce.net was updated with Slovak JJ tubes - GREAT!
It get much better bass impulse and did step forward with overall clarity...
JJ tubes are best! 😛
I have got some 807's valves.please can you send to my e-mail the squematic diagram of your amplifier?.it is: jmiguez@tecnav.es thank you very much
Hi,I have got some 807's valves.can you send to my e-mail jmiguez@tecnav.es your squematic diagram.thank you very much
Well, that little old scope served me for quite some time.
After a diy-break of several years I turned it on and it worked for about two minutes. Power light is on, but nothing on the screen.
And I really need my scope now: I just finished the first mono of a new PP KT88. It is quiet, even on high efficient speakers, but I can't get stable AC readings on my DMM.
ECC99 LTP with a LM334 CCS as the tail, set for 5mA, directly coupled to a 6SN7 driver (shared 12k cathode resistor, 8mA total). The KT88's running in triode @ 465V, driven by IRF820A's as source followers.
I think you need to add gridstoppers on V1 and V2 to stop a possible oscillation.
"Menatzchim" C3m tube preamp in a 1UR enclosure with Jensen copper,paper and oil caps and silver leads. 3 switchable inputs on rear.
WHAT?! More than one tube in a stereo preamp?:
Beautiful amp!!!
Hello
I do like these C3m tube a lot. Can you post your preamp schematic please.
Thank you🙂
Greetings Gabor
Each tube only has a single pentode. I recommend you don't use a Ck but if you do 150uf is the valve. A 10V version is sufficient. I used a 0.47uf Jensen copper, paper and oil cap on the output. According to the designer (Matt) it is OK to use 0.47 and not 0.33uf.WHAT?! More than one tube in a stereo preamp?:
Beautiful amp!!!
Thanks for the nice comment.
Hey guys,
i also want you to show my KT88 Single Ended Amp. Its the best Amp i have ever build 🙂
In the photos you can see 2 different rectifiers, i changed it finally to the bulbed version of the 5U4GB.
A preamplifier is still in plan.
A clean, solid build. What kind of finish is that on the plate (the one pic makes it look gold-ish) and what are you using for feet?
thank you.
The feet are from an old computer case from Lian Li (link to picture: http://i1-news.softpedia-static.com...mmer-Case-with-HPTX-Motherboard-Support-2.jpg )
What do you mean with plate? The main plate of the whole chassis? That ist just alumium color, the heaters makes it look like gold 😉
thank you.
- Tubes / Valves
- Photo Gallery
