can i please get some help in how you would design the enclosures for the below drivers so they would work with an active-XO fast style set-up.
I have hauled the bass units from the T-TQWT towers i made a while ago to try a FAST style set-up as a plan B if my next attempt at a BLH for the 8inch driver doesn't give me something i like.
2x 8 inch full range units.
Fs - 58hz
Re - 7.6
Bl - 12.23
Sd - 216
Vas - 36.755
Qed - 0.25
Qmd - 2.97
Qtd - 0.231
4x 12 inch woofer units (need to double check params as they're crappy)
Fs - 37hz
Re - 7
Bl - 19.4
Sd - 520
Vas - 69
Qed - 0.44
Qmd - 5.28
Qtd - 0.406
thanks for your help
Fs - 58hz
Re - 7.6
Bl - 12.23
Sd - 216
Vas - 36.755
Qed - 0.25
Qmd - 2.97
Qtd - 0.231
Fs - 37hz
Re - 7
Bl - 19.4
Sd - 520
Vas - 69
Qed - 0.44
Qmd - 5.28
Qtd - 0.406
ok, rephrase the question.
the box is going to have 2 chambers(?) each tuned differently. in terms of a mechanical crossover between them, do i design the FR's box first, then match the 'bass' box to try and crossover, or do i design the 'bass' first then try and match the FR to it?
if this was the enclosure plot for the bass drivers, do i simply try and match the FR enclosure to approx 98db @ 200hz? which i think is about 6ltrs tuned to 100hz (see below).
ok ignore the crossover questions.
what are the potential pit-falls in these 2 set-ups?
displacement is accounted for and the FR would be contained within its own ported 'box' internally.
what would the difference be between the 'D'Apolito' set up and the 2nd set up in terms of audible differences?
This will require the lower one to be a band-pass and the other a sealed or TL alignment.
Hmm, do you build a roof or foundation first?
GM
A lot depends on where the HF is in relation to your ears and how far away you listen.
GM
which is considered the foundation? the Fullrange unit or the bass units? I had assumed the FR unit, as the concept of FAST is 'full range assisted'.
also if i may further pick your knowledge; i've seen Planet10's FAST system's with side mounted woofers, can this work with any woofer and design? infact, could the woofers be mounted on the back of the box? what are the major differences in the sound produced when mounting front facing, side facing, rear facing?
thanks again for your help
edit: ignore rear mounted, just simulated it with MJK and its not pretty.
You're welcome, though your latest Q implies that you have no idea how sound is generated, but surely you know that the lower the frequency, the longer its WL, ergo the more massive it is, right?
GM
I do understand that, I'm not entirely sure how this fits in with my question tho, sorry.
if this is the sim for the above design, would the sealed plot work well enough to cross to the bass units?
It doesn't seem so since the fundamental [low] frequency is the 'foundation' of all sound.
Historically then, the bass BW reproducer is designed first, then the mids, HF. If a true sub system is used, then this is the foundation.
That said, I keep forgetting that around here the wide BW driver is typically chosen first, then any bass, HF augmentation is tacked on.
Fortunately, the woofer, [super] tweeter selection is so large nowadays that given time one should be able to find a close enough fit or at least one that can be blended with a custom XO that now can be easily designed using either software or adjustable digital XO.
GM
Ideally only if the woofer
Since our hearing acuity dramatically degrades down low, many folks can tolerate up to 1 WL away, so it depends on the person's hearing and the room's acoustical conditions that will set the max acceptable offset.
GM
Yes, though you'll probably need an adjustable digital XO to dial it in if you don't have measured in room responses to plug into a computer program.
GM
- Full Range
- FAST-ish enclosure help.
