I was told if I loved the warmth of adcom then I would love carvers tfm-25 I can say there is no truth to that the adcom blows away the carver in almost every way except maybe the carver is brighter in midrange that said there is no presence in the carver nothing that makes you want to listen to the carver. I got rid of my adcom for this amp makes me sick. Can anyone tell me what amp in the price range of these two amps that has the presence of adcom if any meaning the warmth. Thanks ahead of time for the response
I'm not quite sure what you are asking.
I am not sure that you can find another amp that is as good as, let alone better than an Adcom 555 in the same price range.
I must confess my bias, I run a tri-amped system, all Adcom:
565, preamp
545 II, tweets
545, mids
555, bass
And reason not to get another 555?
Good luck.
565, preamp
545 II, tweets
545, mids
555, bass
Good luck.
well I want brighter midrange but not the ear piercing from the carver adcom is good don't get me wrong, but audio bliss is what I want, I have the BA 1 boards I can make a ba 3 but it would take alot of help from those who know what they are doing to build it would the ba 3 get me the power and beautiful sound I am looking for?
The nelson pass designs on here
Weird responses.
IMO/experiences the Adcom was a Dawg..
Cheap *** builds with the least amount of sophistication possible to produce a working unit at minimum cost.
Carvers' were always second tier as well. Sad but true and I knew the man.. just to add injury.
Bare,
Hi. More helpful if you add your recommendation and not only your condemnation.
The Adcom GFA 555 can be picked up for about $275-375. It is a nice amp and at that price it is a great value.
They are getting older, so it is wise to check for DC offset and check the bias. The electrolytic caps should be replaced. The main PS caps can be bypassed (done in the later version) and it should sound great. IMO, its strength was a clean and tight bass (with the new caps)
Good luck
Good luck
- carver tfm-25 vs adcom gfa 555
