Denon DL-103 and 103R
messing is the dutch word for brass..
Not sure why they are called "slotted brass cylinder head screws" in Dutch, but I guess that is a loose translation of cheese head screw. I don't believe it is a literal translation, can't imagine brass would be a good material for a real cylinder head screw. 😀
Perhaps one of the Dutch speaking members of the forum can set us straight.
The SPU Royal has a line contact stylus, and as an owner of two other SPU (A GM E II, and Meister Silver GM) I am curious about the issues with line contact styli. I have been told by several that setting up a cartridge with a line contact stylus is much less forgiving than an elliptical or spherical stylus. I'm still a bit skeptical about the spherical based on my less than stellar experience with a ZU Denon DL-103 on my Schick arm, not bad but the sibilance problem on female vocals and occasional mis-tracking on hot material turned me off. I guess I could get a GM II or something similar with the spherical stylus and try to figure this out..
Assuming you are replying to me the DL-110 is an elliptical, and sort of far removed from what I am looking for.. 😀 If I'm looking for anything it's for a spherical in the same performance range as my Meister Silver or there isn't much point.. 😛
No question it is a great starter cartridge, but I also have a mediocre sounding DL-103D (I think due to age the suspension is a bit past its prime) and a Goldnote Bobboli which should be several notches up the food chain from the DL-110...
I guess i need to get out of starter mode ..... 🙂
Starter mode might be the most fun place to be.. 😀
Have to admit though that I love my various SPUs and that there are definitely more of them in my future, they are phenomenal.. :cloud9:
Yes the MS has a nude low mass elliptical, and the Classic GM E II a higher mass nude elliptical. The MS is a significantly better cartridge than the Classic, but I enjoy both, and am listening to the GM E II on my second TD-124 right now.. 😀
