Batch 1 subscribers who are interested in a set of pcbs with the correction to the cap boards please post your interest here.
The cap boards (only) will be offered as promised at 50% cost, not including postage.
If you would like a full set of PCB’s state option 1.
If you would like just the cap PCB’s state option 2.
Lastly please confirm how many sets. A set is one complete amplifier.
This offer is exclusively for the subscribers of EUVL’S Batch 1 F5X.
A show of hands will help us work out final cost.
I’ll start off:
Johnwmclean Option 1 / 1 set
I’ll start off:
why should one want a complete set?
Aversion against mixing blue (old) and black (new) PCBs in one amp.
Do the new cap boards also exhibit larger diameter (35mm) for use of 22000µF/35V TS-HA caps?
There is a special version of cap boards which will take 35mm caps (see attached).
As you can see, no terminal blocks possible in the same footprint, and specially made Delrin blocks required.
So I am not going to offer this unless you are prepared to pay for special one-off machining.
Patrick
Patrick
I’ll start off:
flg Option 2 / 2 sets
I’ll start off:
Horio Option 2 / 2 sets
** Withdraw after seeing Greg's countersink result
I am withdrawing from the GB as well, as the countersink trick worked well and was fairly easy.
On our record, flg subscribed for one case only, so only one set entitled.
Please correct if I am wrong.
flg Option 2 / 1 set
Since the majority is happy with countersinking, and there is no real demand, there is no justification for a run on its own.
So you will only get these around April 2013, when we order the Batch 2 boards.
Patrick
Patrick
Patrick
Thanks Patrick, seeing Greg’s good work I am more confident in drilling the Delrin blocks and it does make sense considering the waste at hand.
- Group Buys
- EUVLS F5X -- PCB GB Limited to Batch 1 Subscribers Only
