Picked up a third head. This is a single-ended class-A champ kit somebody else already assembled. Price is right as long as the tubes are still good. Looks like about 5 watts. I think it's only got a volume control. 2 audio signal tubes and a tube rectifier.
There are some champ kits with parallel single-ended class-A outputs, which look really interesting.
This should be fun. I'll have to decide on a speaker and make a cabinet. This project might sit on a shelf for a while, or I might run it as-is.
I wish I could figure out how to make a nice faceplate for it.
I've got a single ended project in mind also, and I'm planning to use a 12" speaker to for a few reasons, mainly to allow for more options as 12's are the most popular size. Also I don't want to sacrifice bass, even though it will be a relatively low power single ended amp. I would recommend a 10" or 12" speaker instead of the typical 8" found in the Champ-Amp.
I'd love to see what you come up with for a DIY solution. I'm lazy, I just use Front Panel Express. I've had these guys recommended to me a few times too: Amplates.com Custom faceplates, nameplates and grille cloth for guitar amps .
For the panels, I found Laser cutting and etching service - Specializes in customized products, including control panels, nameplates, and logo tags - Precision Design - welcome but custom stuff ain't cheap.
I'll check out amplates.com for sure!
I was lucky to find a new Fender faceplate for my super twin (converting combo to a bass head).
It arrived yesterday intact, packed as a chassis in a box with tubes sticking out the top of the chassis! The whole thing is so light! I hope to try it tonight. I will be listening for low hum and hiss.
I was surprised the filament wires are not twisted. Inside it looks surprisingly random.
