Expensive transformer for bass DI?
Just a bass player here, deer-in-the-headlights type, one each.
I've read that the secret to a great sounding bass preamp/DI is an expensive transformer. Seems to me I ought to be able to locate such a transformer as surplus/used instead of bleeding money.
Can anyone point me to an understanding of what a transformer in a preamp/DI does, why it is critical, and what I'm looking for? I'll take the smallest, simplest clues, pointers to stuff others have tried, basic tutorials, anything. I could google, but I wouldn't be sure I'd be avoiding irrelevant or bad advice.
Thanks in advance!
Basically, a DI transformer converts signal level and impedance from the format that your pre/bass puts out to what a mic input on a desk expects. This is a standard item, so searching manufacturer's websites such as Jensen or Sowter will give you plenty of options. However, in your situation, I'd just buy an EMO single channel jobbie. They are an industry standard in the pro world and will do everything you need.
I didn't want to get into the gory details, but this is about the latest studio good luck charm, the $745 Reddi DI that has a 6N1P and is very heavy. There's a huge following for this box. Now, I'm somewhat of a tube freak, if an ignorant one. I rolled hundreds of tubes and found a winner, and to me, the "tube sound" is all about astounding accuracy: http://www.bassfrontiersmag.com/wp-content/uploads/Vol8No2.pdf .So I was much taken aback that this box, which to my ears sounds like it's all about mushy bloom (listen to samples on basstasters.com )is all the rage. Well, it's probably true. Everyone says just get one, engineers are used to working with it, it takes no tweaking so they're delighted to see one, but when I suggested that one of its major proponents try a better Russian milspec tube, he said he did, but, it made a hump in the EQ and he blew it off. What I'm guessing happened is it reproduced his signal accurately. And since he admitted it was otherwise an improvement, I'm guessing the stock tube sucks. Now I want to find out what all this is about, this big transformer and all. I don't know what else is in the Reddi, but I figure if folks here can tell me how to build the best single-tube preamp/DI I can build, then I'll have something worth wrapping around one of the two magic tubes that turned up for me, and I'll maybe be able to demonstrate what I suspect, that folks are confusing "tube sound" with their favorite EQ flavoring, which is ugly to my ears, muffled and muddy and masking what a good bass really sounds like, which, on reflection, may be unappealing to them, but the electric bass is what it is, and it's good enough for me, magical, even.
We would probably need to know more about how you want to use it; live or studio, direct to pwoer amps or crossovers or mixing board, consistent setup or continuously changing.
There's cheap direct boxes and expensive ones. Places like Guitar Center sometimes have really cheap direct boxes on sale as loss leaders selling for less than the parts cost. The input for a board or even power amp input is sensitive enough that you really only need a little transformer. BUT live sound can have a dynamic range far exceeding the norms for any recorded material, and you also need to accomodate the mismatches and volume changes that occur during a live gig. Low-frequency extension increases the amount of iron required, but IMHO the advantage of a bigger tranny is being able to drive any load, even if the guy at the board has a big pad on your channel.
T A Weber sells a kit for building a balanced low-impedance output into your amp. It uses a teensie transformer, and works as long as you drive it with the correct voltage, so it includes resistors and a potentiometer. I'm sure you can source the parts even cheaper. It's intended to connect to the amp output, not preamp output, but can probably be used for either. But it has no meter, so I imagine you have to adjust it every time you change the volume at guitar or preamp, and work with the guy at the mixing board to adjust his pad and level using his VU meter, as you need to keep your drive low and the board input sensitive so that you don't overdrive the transformer.
For many years the Jensen "BM" series balanced output transformer has been nicknamed the "Big Mac" (for "BM" series), and it is big and handles incredible dynamic peaks at low frequencies while delivering considerable voltage into low-impedance loads. They're commonly built into high-end PA mixing board outputs, active stage box outputs, high-end tube mic preamps, etc. It sure doesn't sound flabby. That's probably the high-end. It will drive very long lines, very low impedances, at very high levels. It delivers a balanced lien level, much more than just balanced mic level. Sounds GREAT IMHO.
Little transformers can work fine when adjusted perfectly, but the big ones are more forgiving.
The transformer isn't just to make the match, it's also to keep the output balanced so it doesn't pick up hum or RF. Of course, if you're not driving long cables you can use higher impedances, unbalanced, with much higher drive levels and not even use a transformer.
Whether to spend the money depends on how often you plug the preamp directly into different boards or other equipment with different input impedances or need quick setup for live shows.
I have been very happy with Edcor for very good value with other transformers. I have not tried their matching tranformers for a balanced low-impedance output.
The bottom line is that you need to test for yourself.
What's your budget, and is the DI side or the preamp one most important to you? Personally, I don't consider Jensens to be all that expensive when put into the context of my design and build time. A friend of mine on Talkbass swears by a cheap reversed mic transformer-in-a-can though.
I guess it depends on whether you want to achieve balanced line levels or balanced mic levels. Sorry I don't have time to look up the details, I used to just call and order the "BM" line-level output transformer. I've always been very pleased w/ Jensen (not to be confused with the speaker company), good input transformers too, good shielding etc.
There's no doubting that a Jensen DI transformer will give a good sound, just whether, for a particular application, it's worth the not inconsiderable sum it costs. I have, over the years, collected a fair number of mic input transformers out of scrapped out tube studio gear (and occasionally installation PAs). I've found that these, while not designed for DI, gave a precision in the sound sufficiently exceeding miked speakers that I've frequently had to filter them down to prevent them invading the mix – live or studio. Driven fron a low impedance (which even a tube preamp should be), their frequency response is more than adequate, and at bass guitar frequencies (which do not descend into the chthonian depths like synthesizers and bass drums) they give masses of level for anything with a mic sensitivity input before any core saturation.
For the 10kΩ transformer mentioned above I'd recommend a cathode follower, or it won't be the transformer distorting but the tube driving it.
What do you regard as expensive ? Here you can have transformers by Neutrik that go down to 30 hz and cost around USD 30 (probably more in the US) in the "naked" version. If you want one that is capsuled in u-metal then it costs about three times that much.
If you have a transformer with three windings you may probably use it with some NFB to further reduce THD and improve FR at the same time.
Charles
The thing about transformers is that their bass response depends mainly on the primary inductance and the bigger the inductance the better the bass response. Obviously more inductance costs more money so it it is not surprising that a good transformer for a bass DI is going to be expensive. The cheap transformer made bu the likes of OEP have relatively low primary inductance and so are not ideal for bass DI. The more expensive makes like Sowter and Jensen generally have a much higher primary inductance and hence work better for bass DI.
Cheers
Ian
