As you can see, this is my first thread and I'm new to computer audio.
I am working off my own build and am experiencing a significant amount of static/noise from my speakers. The static isn't present when the speakers are plugged into my laptop, so I think the speakers are fine (Mackie MR5 MKII).
The static seems to correspond to my actions on the comp, like clicking, scrolling, loading a web page... is this my motherboard? Can the power supply cause static? I recently purchased an audio card - ESI Julia - and have the TRS line out connected to my speakers. I had hoped it was the auxiliary jack on my mobo but the static is even more present with the audio card.
Any general info/help/walk-through of how to eliminate the static would be extremely appreciated.
Thanks!
Thanks!
You are running the PC at full volume, in both windows and the player right? Adjust volume on the speakers...
Its either your keyboard/mouse if you have PS/2 keyboards, try and isolate the cables of the keyboard/mouse from your line out cable by at least a few centimetres. Consider getting a USB one. Gigabyte makes a nice USB keyboard and mouse that you could get for under $20 for both.
Are you using VGA output from your soundcard? if so try and use DVI.
Could be a faulty video card or sound card decoupling capacitor.
From experience though I've found it to be the fault of cheap/shoddy manufacturing practices in the soundcard.
Volume sliders on my system are set to 1/2 way as a matter of practice, I strongly suggest that you keep the volume sliders on your PC as lonw as 1/2 way, maybe even lower, and just use your amplifier/speakers to do the amplifying and NOT your soundcard.
By putting them as high as possible you are also amplifying the noisefloor, so its good practice to simply keep them half way.
As a bare minimum I would suggest that you get a DAC and use digital/optical output from your PC, if this is financially possible.
Set your computer / sound card / software / OS volume to near maximum or at least 50%, then reduce the volume control setting on your speakers.
I'm not sure it is correct, volume should be at max for the best SNR.
If you take a low volume from the sound card and amplify that in the speakers you will be amplifying the noise but not the other way around.
The ESI Juli@ is a very good card, it should be clean.
If you are using an outboard DAC then you must be at 100% for it to be bitperfect.
Which plateform your computer uses?
Sandy bridge and PCI audio cards is known for showing that problem.
Some mobos are bad for audio.
Using a gamer video card can be a problem too as it draws consequent current spikes.
I've found that it can introduce distortion, most soundcards that I have come across will go far and beyond 1v p-p on line-out.
1. Can you hear the same noise using the unbalanced output (simple 2 cinch - stereo jack cable)?
2. Can you hear the same noise through some cheap skype headphones/ small passive PC speakers hooked directly to Juli output, without any grounded amplifier in between?
Gentlemen, thank you for your replies. Heres some more info based on everyones feedback:
My speakers volume control knob on the back are at 50%
My player (winamp) is at 50%
The Juli@ outputs are around 50%
I am using an RF wireless mouse, could there be feeback from this? Might explain the static correlating with clicking, scrolling etc
Running win7 64 bit
Yes i can hear the same noise when running unbalanced rca out
Running win7 64 bit
I think the important information is if you can hear the same noise through passive speakers/headphones. The culprit my be ground loops - your active speakers have the PE wire hooked to ground.
JENSEN TRANSFORMERS, INC. - ISO-MAX® CI-2RR Stereo Audio Input Isolator
Worked for me and made me a believer in transformers.
What Danieljay describes is a noise produced by the computer, nothing to see with hum.
I encountered the problem. Using another plateform solved it.
I looked into that... I tried using a two prong converter on my speakers to eliminate the ground but still got static. Also, i do not hear the static at all when plugged into my laptop via unbalanced rca with the same active monitors
I think you are right... what do you mean another platform?
The static corresponds with hard drive read/write - meaning i can hear static noise that corresponds to opening/closing programs. Scrolling, dragging desktop items... performing a Windows Experience Index really made the static go nuts.
As I said, the Jensen solved the problem for me.
Whats your setup?
Did you identify the mobo as the source of the noise?
well that would be a problem with your amps or somewhere else, the soundcard should be set to 100% or as high as possible, if you have it set for 50%, you may as well forget about any audio tweaks, your SNR will be reduced as a base level far more than you can hope to improve it elsewhere in the system. the output of the soundcard should be higher than 1vpp... single ended line level is 2.1vrms. if 2.1vrm clips your amps, your gain structure is all wrong, adjust the gain in the amps, digital attenuation can be very good, but all this needs taking care of first and perhaps do the digital control somewhere with a floating point controlI've found that it can introduce distortion, most soundcards that I have come across will go far and beyond 1v p-p on line-out.
as for the sound danieljay, its whats called blitter noise, your audio card is possibly in a PCI slot next to the graphics card yes? try to avoid this if its causing you issues, shuffle the cards around if you can. thats what it sounds like anyway, it changes in tone depending on what colours are on the screen yes? if so its a radiated noise from the graphics processor either radiating noise into the analogue ground or signal, or simply causing ripple on the ground through transient power demand.
I had exactly the same problem, I could hear even letters appearing in terminal (slow server connection), basically any screen change was audible. My soundcard (juli and quartet) was hooked to a small t-amp supplied by 12V of the PC power supply. Using a small independent PS with no PE ground connection eliminated the noise, idle speakers are absolutely silent now.
- PC Based
- Computer based static/noise?
