Push-pull implemented with KT88
Hello,
I am planning to build a push-pull KT88 based amplifier. I would like to make it operation type selectable by using a switch, so I can operate the tubes at Triode, Ultralineal or Pentode, depending on my PWR needs, and mostly for audio comparisons purposes. Fixed bias provided by extra turn on xfmr.
I could use a different tube rather than KT88, but what the h*ck, it's among the best tubes in its power rating. I haven seen some pcb boards (like pmillet's) that come very handy if testing and breadboarding, but it will be a final assembly, not an amplifier to experiment, so I will P2P it.
What is a common, high-end, not very complex schematic to use? I don't really care if it is a complex desing, but life's such, that simpler ones use to be the better ones. I don't really need to be able to select between triode, UL and pentode, that's something I am able to put in by myself 🙂
If you were about to build ONE, with these requirements, what proved schematic would you implement?
Thank you and best regards,
Regi
Look to the Dynaco schematics with modifications to the driver board, a ton of them floating around, for the Monoblock's look for the MKIII amps and for a stereo version the ST70. Lots of transformers from several sources and I think just an update to the driver and you will have a simple good sounding amp.
Sandy
I think I am going with Triode Dick's, but I can't find anything related to output transformer impedance, power and other characteristics on its website. Do you know what is used in the original design or should I just calculate it?
Link to the translated website:
Bill Part 7
No feedback ?
This type of circuit usually benefits from some low feedback. The feedback will also affect the gain of the amps input/driver stage. Does anybody else think feedback would help on the amp?? What's the sensitivity or the voltage needed to drive the amp to full power?
