Having made dipoles I have come to like the ambient sound which sounds more natural in nearfield listening in moderate sized rooms. The dipoles can only be shrunk so much though.
So perhaps a omnipole or bipole can be as good in providing the same ambient effect in a smaller package than a dipole. Indeed SL also compares the Pluto very favourably to the Orion for the ambience at closer listening distances. Unfortunately omnipoles need very small drivers and narrow to non-existent baffles to be omnipolar, thus limiting high SPL applications. Also simple omnipoles like the Pluto have omnipolar radiation to about 2000 hz only.
So it seems that bipoles would be the best solution for an ambient soundfield with good dispersion to more than 15KHz, at high SPL in a smaller than dipole package. Does anyone have experience with comparing omnis to bipoles ? Thanks.🙂
Why do you want "high SPL" in "moderate sized rooms"?
PLUTO is effectively omnipolar to something closer to 4kHz . . . it is not like there's some "brick wall" at 2000 hz where the pattern abruptly changes. And, should you feel the need, you could always add a "rear tweeter" to PLUTO. You might also consider this:
Trevor Marshall - Ground Effect Omnidirectional HiFi Loudspeakers
Got some examples of good omnidirectional bipoles?Most bipoles . . .
Thanks for the link dewardh 🙂
However I really doubt if Trevor is having HF omni radiation from this driver Peerless Tymphany 830893 as its polar response becomes quite narrow after 4KHz and pointing it upwards will likely have no focus of the auditory image😕
Actually I am not after higher SPL but rather lower extension which would also mean more displacement than a 5" woofer could manage. without running out of xmax 😱
Most bipoles will be closer to omnipoles than Pluto.
dave
Yes Dave, I too have the same suspicion 😉
at least based on theoretical reasoning. Just wanted to have somebody support my ideas with practical experience 😛 while I continue to experiment 😀 with wider than deeper bipoles.
Only thing bothering me is the inevitable edge diffraction effects on a wide baffled bipole compared to a minimal baffled omnipole like the Pluto.
if you want real (raal) omnipoles, built this:
RAAL Requisite Eternity Omni-Directional Speaker System | Tuvie
I am building it at the moment (not raaly)
puns intended
puns intended
A popular one -- particularily in the castle version with up-firing driver. http://www.diyaudio.com/forums/full-range/148901-microtower-bipolar-ml-tl-chr-70-el70.html
Bipole Metronomes. Dual driver versions of Lotus, Coniston, Windermere.
dave
Well that's not bipole. I sort of lost patience at around page 12 of the thread . . . are there any polar or even 90 degree axis plots for that?
Actually it stays quite broad well above 4kHz, and used with the placement as Trevor uses it (at floor level) one could easily stay in the "omni cone" to well above that frequency. I haven't duplicated his specific design, but I have experimented with that driver, and even in a box (on a baffle) its dispersion is surprisingly broad. One of the problems with "bipole" (apart from the beaming from generally larger drivers) is that because of diffraction related to box geometry you do not get the desired smooth (omni) summation off axis.Thanks for the link dewardh 🙂
That's going to be true of anything, "bipole" included. The L16RN-SL has a lot more linear stroke than most (even a pair of) drivers its size, and by design its surface area is more comparable to 7" or even 8" drivers. That translates to more bass capability (and extension) than a quick glance would suggest. If you want lower add a sub . . . they are all "omni" anyway. I've heard PLUTO demonstrated in rather large (25x40 ft.) rooms, and bass was not an issue (at reasonable listening levels and "acoustic" source material). As far as the polar goes there is absolutely no "sweet spot", and the "sweet area" covers very close to all the room. And again, if your tastes run to bulging the car windows you're going to want a sub regardless.Actually I am not after higher SPL but rather lower extension which would also mean more displacement than a 5" woofer could manage. without running out of xmax 😱
Why do you say that? It is the very definition of a bipole.
dave
With one driver on the side and another on top? That's not "bipole" by any definition I know. And it's not likely to be very "omni" either . . .Why do you say that? It is the very definition of a bipole.
The regular version i was referring too.... The castle version is for those that want to place them close to a wall. It acts like a mirrorm making them closer to omnipolar.
dave
dave
Thanks dewardh....I never realized Trevor's speakers are meant to be placed on the floor !! This sure is an unexplored means of getting omnipolar radiation for me so far 😱
- Omnipole vs Bipole ?
