NEW version CM6631 24bit/192khz USB to Coaxial and Optical fiber
Listing in China for just a month and became a hot seller, a lot of audiophiles discuss the board in China domestic forums. This board with top grade IC chip CM6631 attracts so many audio lovers!
If someone needs it, just PM me.Thanks.
Picture are here: http://www.diyaudio.com/forums/digi...1-24bit-192khz-usb-coaxial-optical-fiber.html
here is the link selling on eBay, this is my friend's store. also you can pm me if someone want to have a try of this board, thanks.
NEW version CM6631 24bit/192khz USB to Coaxial Optical fiber case by weiliang | eBay
cm6631 always upsamples 44K to 48K
😡 I have one of these but it always upsamples 44K to 48K despite all settings be correct to replay 44k native rate in player, asio4all & w7 device supported rates. Tried both hqplayer & foobar (ASIO modes)
48K & 96K replay their native rates OK.
Installed driver is c-media usb2.0 high speed true hd audio 7.0.1.4
I have many many problem with your device.
Me and my friends bought 9-10 Pcs and some of them not support to ASIO also not recognize to USB2.0 (removed virus scan) also external power supply there're no light and does not work.
Have you test it surely before send them to customer ?
Regard
Anadigit
Regard
Anadigit
Regard
Anadigit
Hello Anadigit,
Where do you get the boards? give me the link, we always ship the items after fully tested and also send the buyer the driver.
I also have trouble with this device. It not recognize to USB 2.0 and Win 7 64 driver works 24bit 48000Hz Maximum. Installed driver is c-media usb2.0 high speed true hd audio 7.0.1.4
I sorted this by uninstalling driver w7 installed & installing driver from vendor.
I now have 4 of these units & they are all fine (3 with 88k & 176k firmware).
Always you have to uninstall driver w7 installs & use vendor driver, this is weakness in w7 (XP gives you option to install from location of your choice, which is what you want !).
Also you have to open device properties and tick sample rates supported.
Also if you use different usb socket you need to install drivers again.
Please consider adding I2S input header for this device as well, it would make nice sound card, too.
Hi!NEW version CM6631 24bit/192khz USB to Coaxial and Optical fiber
I've recently bought another version of your CM6631 board for DAC7 (link). Could you, please, send me firmware for it. I've tried some other CM6631 firmwares found on diyaudio.com, and now need to flash back to original (0101 as I remember).
I've PM-ed you my email.
Thanks.
I second that. A CM6631 board with both input and output would be great.
I'm a newbie here 🙂
Agree
It will be the perfect external USB sound card for my laptop to run my DIY sdr station.
24bit/192Khz line I/O to decode the I/Q signal is a must and I'm convinced there are 1000 out there looking for a such board.
Astrax
Agree
Astrax
how do you unistall W7 driver?
Iam not able to use the supplied driver. It gives an error message saying Please connect the CMEDIA Audio device..
Rgds
Rgds
I installed the new CM6631 board today. Loaded the drivers and it plays great. I desoldered the LED and hooked up the wires to the case USB LED.
I can't figure out the LED though. The old USB board only lit the LED when the computer was plugged in. This one comes on at power up. Is there a second spot to wire in the case USB LED? If there is I can't find it.
Hi Mr. Weiliang.
I have bought 2 DAC7 with CM6631 USB modules fom minishow seller (user RAZOR2000SHOP). These units work fine but I have a problem with CM6631 when I try to play wave file in 192khz 24 bits resolution. The sound is good but I have also several scratches noise (non periodic). I'm using a TOSHIBA TECRA pc with WINDOWS7 but the problem is existing also with other computers.
Someone told me that is necessary a new firmware. If this is true could yuo send me the firmware, the installation tool (for WIN7) and the instructions how to do it?
My emai is: roberto.marin@mail.wind.it
Thank you in advance.
R. Marin.
R. Marin.
- Vendor's Bazaar
- FS: My new design: CM6631 24bit/192khz USB to Coaxial and Optical fiber
