psu for lme49810
wont you need a current limited supply, in case you short output stage?
If you have an ordinary (V)I limiter over the emitter resistors, then this will pull a lot of current through the driver stage, ie LME498XX and almost short this out.
If you have a current limited supply, then eventually the LME overtemp protection will cut in because of the high V*I drop.
Thanks for your effort, Tony. Me thinks PSU and chip are interleaved and thus deserve a disussion despite this thread have a different direction.
Especially since I have not found any info regarding.my question neither.reply from NS (TI)
I will reread the threads again.though as one might easily miss out on important information.
