line level stereo volume control using one pot?
Are you looking for something like this?
VCA's.
use one single pot that controls a DC voltage, which controls a VCA IC, such as the THAT 2180.
http://www.thatcorp.com/datashts/THAT_2180-Series_Datasheet.pdf
advantage here is that you can control "infinite" amount of channels with one pot, downside is that it will require some circuitery.
but, it's an option 🙂 I am building a monitor controller now, with those VCA's, and so far, everything works out well...
I was looking for some kind of IC or transistor solution. Like a voltage controlled variable resistor type of thing.
It can be done with 3 single opamps and a single pot 🙂
I came across this idea many years ago and credit for this goes to Brian Gough of Xicor. I thought I would throw the basic configuration into LTspice and sure enough it does work...
Its really a variation of the Baxandall active volume control. The wiper of the pot is grounded and the "two ends" control the gain stages. How successful it might be in practice is hard to say. The wiper of the pot must have near perfect contact on the track to ensure perfect channel separation.
It was a very clever idea non the less although one I have never seen implemented. I guess the digital revolution made such processing in the analogue domain redundant.
R5 and R5A are the single pot. If the pot is 1K then if one resistor is 900 ohm the other is 100 ohm and so on.
