Amp is making loud "boom pop" noises every second or so..
I went to adjust the volume on my preamp's metal volume knob (which is grounded to the speaker's circuit) and I got a shock (static electricity shock I presume) and right then the speakers started making a loud "boom click" "boom click" noise over and over.
The amp is wide open and I attenuate the signal going into it from my preamp.
I disconnected the preamp from the amplifier and the amplifier is still sending out this very loud "boom pop" noise every second or so. I even got another electrostatic shock touching the amp when I went to disconnect the preamp.
I wouldn't be surprised if I blew out my tweeters in the speakers because the amp is much more powerful than the speakers can handle--I managed this with attenuating the signal going into the amp.
So I gather some circuitry is now bad in my amplifier? It's a dual mono block behringer a-500 reference amplifier, with a torroidal in the middle.
What's most likely the problem with the amp? Can I fix it?
Without seeing the schematic this is no more than blind guesswork, and it could be anything. Switch your scope on and start at the output of the futzed channel and work your way back to the input. When you no longer see the 'kick' on the scope every few seconds you know you've just gone past the culprit.
It genuinely could be any part in the left channel so there's little point making suggestions.
If you only haver a multimeter and not an osciloscope then this might be awkward.....
I would disconnect the speakers and install 8 ohm resistors higher in wattage than the amp power rail supply cap value V^2/8. You may put a speaker out there, just use a junk speaker from the charity resale shop. Protect the speaker with two >1500 uf capacitors back to back, so any DC is blocked by the capacitor.
If you can't afford an oscilloscope, obsolete VOM meters can respond fast enough to find slow AC problems. DVM meters average over 3-4 seconds and will smooth out your boom pop. I like a 100000 ohm/ volt VOM, but VTVM's are also useful. These respond to DC on the AC scale unless you put a capacitor in series with the + probe higher in voltage rating than your wall power supply (200 V peak western hemisphere). Some VTVM's come with an RF probe which has the capacitor already in it.
Then you can check your power supplies. You can't have a schematic, a Behringer repair shop owner has explained the depth of the legal language prohibiting him from releasing Behringer schematics to the internet. But you can look up where the collectors of your output transistors or PS inputs of your output modules, perhaps, and find out what your power supply rails are. They should be lower than the highest voltage rating large value capacitors in the amp. The rail capacitors usually come in pairs, plus and minus.
Zoom pop sounds like a capacitor repeatedly charging up and shorting out, but not always.
Well I am having the same problem with the other channel now on the amp. It got damaged the same way.. I got charged up with static electricity and went to adjust the volume on my DIY attenuator and it shorted it out. I don't understand why it did it again because a couple weeks ago I went through the trouble of grounding the preamp metal chasis to earth.
Is it because none of my grounds are isolated? The negative side of speaker wires are grounded along with power supply etc.. all together. Maybe I wasn't supposed to wire it all to a common ground?
I don't know what to do now. I was going to buy another A-500 but I fear blowing it out as well. I blew both channels on this old amp within a couple months.
The "grounds" of the speakers should be handled by the amplifier, not you the consumer. Your only responsibility is to ensure the 3rd pin of the power cord goes to a valid earth connection in your wall plug. I don't know if you mean you found the speaker returns to be at earth potential because you measured it, or if you actively did something to connect the speaker returns to earth, or to each other. The latter two are not correct, those are the amp designer's perogative. My PA amp does some funny things with the speaker "returns" so that the two halves of the amp may be "bridged" to make a big mono amp. Yours may be the same or different.
The disadvantage of Behringer is the no disclosure of schematics. The other is that people are always on here asking questions about them, even when fairly new, which give me the impression that they blow up a lot. Any amp tends to fail after 20 years if time sensitive components are not changed. I might suggest something else next time if you can't fix this one, some brand you find you can get a schematic diagram for before you buy it. Also, no secret transistor part numbers is an advantage. You will see in my signature what brands of used equipment I have bought. This is true of those brands, except the Herald mixer which I traced out and drew myself on notebook paper. But then, I paid $15 for Herald, operational with good potentiometers (and a stupid hissy hummy design) .
Can anyone recommend me a DIY amp for my RS-2001 speakers that would sound as good as the A-500 or better that won't blow up on me?
The Infinity RS-2001 speakers sound really nice (from 60hz on up).. so I'd like to continue using them. They are 6 ohm speakers rated at 15-75 watts of power. So I guess an amp with 75 watts per channel.
I suppose I could use this Behringer A-500 chasis and maybe even the torrodial transformer?
You don't really get any safety or performance benefits matching the amplifier to the nominal speaker ratings. Sometimes a larger amplifier is a better choice in situations where equipment is abused such that clipped, tweeter-frying audio can be output from small amplifiers.
The "Honey Badger" is a substantial but not too expensive amplifier, commissioned and endorsed by the forum. It's the 2nd and 3rd "stickys" in the header on the first page of this forum. Have a look at this one for starters, since economical PCBs are available, good documentation and lots of build postings to view.
My thinking is, that if you are going to build something, make it a worthwhile project that does a bit more than just meet basic requirements. There is often not much cost difference. 🙂
The honey badger seems really interesting. So far I know I need to buy the PCB for each channel and everything on the Bill of Materials.
What I need help with is which power supply, heatsink & chasis. Should I got with two torrodial transformers, 1 for each channel? What's a good chasis to buy that will fit these long cards (I think they are too long for my A-500 case/heatsinks.).
EDIT: Should I buy the universal PSU (cap & diode combo board) PCB for $19 and the Bill of Materials for that? I guess that would leave me with which torrodial transformer(s) to go with and chasis.
Stay with the simplest and most compact build for your first amplifier. It is complex enough without adding excess that can't benefit it's actual use. A 300VA transformer and supply for each channel or a single 500VA transformer will be OK for a budget build with lower PSU rail voltages. This is a reasonable strategy for keeping cost and size within acceptable limits.
The PSU board is a good idea in any event, unless you opt to buy a kit elsewhere such as Fleabay or local sources.
Keep checking the options in the threads but I'm sure others will want to suggest their favourite designs too.
Well perhaps at some later point I'll build a DIY amp. I wish they sold entire bare minimum kits for the honey badger.
Anyways, I ended up going with an Adcom GFA 535. I'll do the few mods to it and find out how it sounds. I've heard it was pretty decent, and at least it has a schematic unlike the broken behringer I have.
