Hi guys,
As been sometime I'm thinking to bypass the electronics of my reel-to-reel tape recorders and get the signal directly from the playing heads.
Indeed doc bottlehead as such preamp;;;but the price 😱ui ui to high for my pocket.
So I beg any of you audio gurus have a simple schematic for such a preamp? with decent performance?
Thank you
Thank you
The only "tape" pre amp I have used is one designed by JLH. It worked fine as all his circuits do. It was a part of the tape player/recorder that he designed.
I do not think I kept a copy of the circuit but you could search in Google for it.
Don
Don
I had been asked once to embed NAB and IEC by a member but heard no news. Here are the circuits since it took me enough time to investigate. Maybe someone with open reel finds them interesting to test their fitness or tweak a bit from there.
edit: revised NAB circuit
The NAB Bottlehead tube pre is pretty good sounding and I believe the schematics are available on that site.
Here is what the above circuits do by the way. First pic is the input IEC response that is corrected to flat by first circuit. Second pic is the NAB correcting EQ the second circuit imposes on the play head's signal. Open reel aficionados may examine. Both are for 15 inches per second. The input trimmers are for loading both low and high impedance heads better since load can affect their HF I had read.
Master Salas,
What imp/resistance head did you model? Does it matter?
And if I wanted trimmers for gain and freq response, where would they go?
And for aantunes, the bottlehead seduction phono amp can be modded to NAB/IEC, it is not as expensive as the eros kit.
Master Salas,
You make me feel short and green with flipping ears like Yoda.😀
I used 5mH lower impedance later heads assumption, and about 350R source resistance. The input does not care but the heads may care, hence the trimming load addition. Good multi-turn trimmers in the passive EQ section (R4 HF) and R10 for gain. Very sensitive in the IEC for R4, see how it goes for 85R example.
P.S. Its only a theoretical exercise remember, it should take some work from here when with the real reel beast at hand. Don't know for peak overload for instance.
page 26 rather in reader count. You never nail for all recorders. Response Curves of Analog Recorders It takes fine tuning with favorite tape and FFT.
I didn't include the accursed TI cover sheet.page 26 rather in reader count. ..
Thankx to all you guys.
Just a small detail I'm not that hardcore in electronics
, so something simple would be the best.
look for a prebuilt kit and contact teh designer about modifying the eq.
you will also have to decide which curve to use.
IEC or NAB?
3.75, 7.5 or 15ips?
Also what deck are you using?
IEC or NAB?
3.75, 7.5 or 15ips?
I know the Harman/Kardon Citation I preamp had that capability; also the Dynaco PAS preamp could be wired for tape head amplification. Schematics for these are all over the web. The Citations are scarce and expensive; the Dynacos are not. Good luck!
Just a small detail I'm not that hardcore in electronics, so something simple would be the best.
Not as difficult to build as with tubes the JFET circuits and dead easy the National Semiconductor OP-AMP one. I have revised the NAB example BTW.
5mH, isn't to low for a PB head?
Why not learning from the Master? Mr. John Curl, a leading expert in the field of tape recorder electronics, is a member of this forum. Try to contact him.Just a small detail I'm not that hardcore in electronics....
On x-pro's site you'll find some values for cassette tape recorder heads.Have read in a Manley manual 2mH to 10mH for most heads in solid state decks.
- Analogue Source
- Preamp for reel-to-reel
