Mr. Miles,
Is this Terminal Protect will work with AX-14??
It does with this one:
hi apex sir,
i finished the vu meter,left side with 21 leds -right side with 21 leds. its very high resolution vu meter, but when i increase the volume to high, the top 4 leds not lightning, including the clipping led also not lightning. where will be the problem?
tomorrow i will post the pictures.
Use 220R resistors instead 560R for vu meter with 21 leds, but amp rail voltage must be about +/-75V (over 30V voltage drop on 21 leds)
Mr. Miles,
Yes, anti-click, thermal and DC protect will work, but with AX-16 overcurrent protect will work.
Thank you sir...
Mr. Mile,
I would like to verify if this regulated PSU can drive stereo AX-14?
hi apex sir, here is the video, only one side finished.
tomorrow i will change the resistors to 220r
Apex vu meter extra leds.mp4 - YouTube
Mr. Mile,
Yes this PSU can drive stereo AX-14
hi apex sir, here is the images.
Nice work, increase the value of 1k2 resistors and the top 4 leds will lightning.
Thank you so much....
and the top 4 leds will light.Nice work, increase the value of 1k2 resistors and the top 4 leds will lightning.
hi apex sir,
i tried with these resistors 1k5 , 2k2 , 2k7, 4k7 ,5k6 -but top leds not lightning.
hi apex sir,
What is rail voltage on your amp, with low rail voltage you can't use 21 leds
dual supply 50v dc.
Voltage on 21 leds in series conection is over 30V... I suggest to use about 12 leds for amps with +/-50V rail voltage.
ok sir , what about top last led resistor 3k3?
can i use this vu meter for b500 and h900? any changes?
VU meter can be use for any amp without changes.
- 100W Ultimate Fidelity Amplifier
