Dear Joachim,
it seems we all have to wait for the parts of the groupbuy, so I decide to begin with the enclosure.
I found the dimensions of the pcb's, but I have no idea how much space I have to leave for your pre-regulator, you wrote you will design.
Thanks a lot to all who make this possible,
Christoph
Christoph
Hi Gandralf,
thanks for your advice, it is very welcome.
I'm not sure if it will work, but I will try to get the
paradise in a case like my Symasym and Hepos, the
three in same size and shape will probably be my
favourite.
I have about 40 x 32 x 8 cm free space inside the case,
it is made of steel with a front added made of wood.
A fourth case just for the transformators and the pre
regulator is only the second choice for me, but if it
will not work out the way I wish I have to follow your
advice.
Thanks in advance for any ideas or support,
Christoph
favourite.
advice.
Christoph
Hi there
after populating those really cute Boards with Resistors
i do need some Spoon feeding about the LEDs.
I know ive been reading a lot about it in the MPP thread.
But it is long time ago since.
And i am an old man.
So
would someone please help me out with those facts ?
So
At least this much is crystal clear.long lead going to the markings on the circle on the pcb.
But i do foggy recall there was a value for every chain.
Sorry for picking...
Well.... use only "normal" brightness leds because each one should drop around 1.8 ~ 1.9v.
Be carefull to place them correctly (one inverted led will prevent normal functioning)
The marking in the board indicates Anode (+) Long leg.
You can use low current leds.
IMO Lowest noise comes from yellow ones but red are also ok
Many thanks Ricardo, I was going to say the exact same things....
- Analogue Source
- Paradise Builders
