opa 2889 buffer circuit
Hi
I need some advice
See the schematic attached . This is from the datasheet of the opa2889.
The link for the datasheet is
http://www.ti.com/lit/ds/symlink/opa2889.pdf
I wish to use this op amp as buffer after a dac and before the amp. .
What does the label of V0 -DIS imply ?
If I want unity gain ,do i short R3?
much appreciated .
kp93300
Hi
thanks peranders and Andrew
The datasheet says it is unity gain stable,
I quote from the datasheet
1FEATURES
2• FLEXIBLE SUPPLY RANGE:
+2.6V to +12V Single Supply
± 1.3V to ± 6V Dual Supplies
• UNITY-GAIN STABLE
• WIDEBAND ± 5V OPERATION: 60MHz
(G = +2V/V)
• OUTPUT VOLTAGE SWING: ± 4V
• HIGH SLEW RATE: 250V/ µ s
• LOW QUIESCENT CURRENT: 460 µ A/ch
• LOW DISABLE CURRENT: 18 µ A/ch
thanks
kp93300
