I'm in need for two pairs of new binding posts for my dMar-Kel70T build.
I found some Jantzen AudioTerminal 1 in Sweden for 138SEK/pair but that's quite expensive.
But I found these on ebay that are cheaper and just as good looking, but are they as good quality as the Jantzen ones?
2-pair,SPEAKER/AMPS TERMINAL BINDING POSTS POST,SRBL | eBay
2x CMC Speaker Binding Post Female Gold 858-LU-R Hi-End | eBay
mundorf terminals from madisound ??
if you like the jantzen ones, why not buy them from, jantzen ?
Mundorf terminals are still very expensive. I do actually have a set of them here at home but they're meant for another build.
I guess I'll go with the Jantzen from Sweden then if nobody else can tell if the ones from Ebay are good or not. But 320SEK ($48) for a set of binding posts is still quite expensive.
Either of the ones you posted should be fine.
Warning! I'm a cheapskate. I see no reason why banana plugs and jacks won't satisfy.
Atlona 10 Pairs (20 pcs) NEW HIGH-END Speaker Wire 4mm Banana Plugs Gold Plated | eBay
5 pair Amplifier Terminal Binding Post 4mm Banana Jack Panel mount connector | eBay
I need speaker binding posts, not amplifier binding posts. I'm using 18mm thick panels.
I want something that has that clear plastic stuff, I think it looks cool.
Cut a big hole in the panel, maybe 100mm by 60mm
Glue and screw a thinner plate over the hole on the inside of the speaker.
Mount your terminals on that thinner plate.
The recess seen on the outside looks nice (in my view) and helps protect the terminals from knocks etc.
check these out, very affordable
http://addison-electronique.com/haut-parleur/accessoires-pour-haut-parleur.html?p=1
I always drop in to this place when I visit Montreal.
Montreal is pretty far away though, like on the other side of the planet. Remember that I live in Sweden, not in America.
Zman: Yes they're cheap and easy, but I want something that looks good too. That's why I want that clear plastic and either copper or silver (gold feels too mainstream).
I don't see why the ones on eBay would not do trick. FWIW, I like Jantzen audio parts, but I doubt here it would make much difference.
Aha... fashion statement. 🙂
So besides the clear plastic here a "Satin Nickel":
Dayton Audio BPA-38SN HD Binding Post Pair Satin Nickel 091-1247
I got a pair of the gold ones some time back - size and construction is good - looks more expensive than the "cheap and easy" one.
Need to buy for at least $50 from Parts-express for them to ship to Sweden.
I think I'll get the Jantzen ones available here in Sweden.
Go to Monacor`s webpages, i belive you find nickelplated bindingposts suitable for 25mm panels there.
Nicklas,
The binding posts need to be removable from the outside, do not be tempted to put them thru the back panel. So you need a cup or need to make your own removable plate. If you do not you will be cursing yourself sometime down the road. Trust me on this.
The Jensen's have far to much metal for me, the 2 eBay ones are cheap clones of the WBT and not worth using (i have cups i retail for $8/pr that outperform those).
The mundorf's look much better but are at a price where one would look at Eichmann Cable Pods or WBT next gens (what i'd use if money was no object). Do note that the big heavy solid copper WBTs are not very good at all, being outperformed by the cheapies i use -- those WBTs can be improved just by discarding the nut.
The ones Ed links to are interesting (dirt cheap/minimal metal if often a good sign, no pretense), but limit you to banana plugs (and i'd get dual pomonas long before i got the fancy looking ones he linked)
Thanx for posting that link Multisync. Of the posts they have, these are what i'd consider the best Bornier à banane plaqué or pour boîte de son - Accessoires pour haut-parleur - HAUT-PARLEUR, but are the least desirable of 4 versions of that cup (mine are the most desirable), they must buy at much larger quantity than i do -- but they do ram home that spending $$$ for bling does not necessarily bring sonic goodness.
The minimalist ones Zia points to use the same posts my cheapies (and the ones from Montreal) use, and are very useful when you don't have room for a cup. I keep some on hand for that purpose.
These are a step up from the cheapies, and a good choice if you build your own aluminum post panel http://www.partsconnexion.com/product7483.html. They can also be fitted into the cups with the cheap posts i have (require some fiddling with the mounting hole)
If you are not exchanging speaker connections often, the best way to use a binding post is to run the internal wire out of the box, and using bare wire connections on both it and your speaker cables, use the binding post as a clamp to hold the 2 bare ends together.
dave
dave
- Design & Build
- Parts
- Binding posts from ebay?
