Salas low voltage shunt regulator (V 1.0 ) for DAC and more
This layout
Old PCB
Quanghao,
I have a complete LV shunt pcb from you sometime ago, but can't find the schematic for it even I search your forum and or your shop. It says V 1.0 on the broad but there is no Leds marked on the broad. Would you please take a look and advise where I could find the schematic so I could go on with my project - The Lightspeed attenuator.
Albert
BTW you can email me if you want.
Sorry I've found a big different with the schematic you showed. Below are what was printed on my broad for 1.5 - 5v.
Q1 IRF9520, Q2 BC560, Q3 K170, Q4 BC550, Q5 K170, Q6 D45H8. You can also check with the picture attached.
hi quanghao,
Using the Salas LV shunt I bought from you also, I will be using with 4 x 34 Vac / 20VA
for the Roender FC-100 amp the Rudi is offering.
What is the best component to use for this application? Shunts will be providing power to front-end of amp.
hi quanghao,
Hi!
yes, can use whit 34VAC, but need change BC550 and bc560 by othe transistor hight voltage.
How many MA do you need for system?
No use for it, because need Heatsinks very bic
