Logic puzzles
Here is an easy one..
You have a lighter and two fuses that take exactly one hour to burn, but they don't burn at a steady rate. For example, one fuse could take 59 minutes to burn the first inch and then burn the rest of the fuse in the last minute.
How would you use these two fuses to measure 45 minutes?
M. Gregg
One for the newbies,
Kirchhoff and ohms law just for fun..
Very easy..
M. Gregg
M. Gregg
Its only easy if you know the answer.
Light one fuse at both ends the other at one end.
When the first burns out light the other end of the other.
45 minutes.
rgds, sreten.
A twist on previous puzzle.
A man is traveling with a fox and two chickens, if he leaves the fox alone with the chickens the fox will eat the chickens. He comes to a river and needs to cross it, he finds a small boat that can carry only him and one animal, how does he get himself, the fox and two chickens across the river safely?
M. Gregg
You have two buckets - one holds exactly 5 gallons and the other 3 gallons. How can you measure 4 gallons of water into the 5 gallon bucket?
You have infinite water and no markings on the buckets..
M. Gregg
