I have just finished building my hi end DAC, it is an balanced AD1865 DAC with 4x Pass D1 IV Stages with CCS's, The digital section uses CS8412 receiver, AD1896 ASRC, SM5842 digital filter, and flip flop re-clocking to the DAC's. The Clock is a symmetrical colpitts oscillator with LT1021 based power supply. The rest of the PSU's are Sigma11 and Sigma22 based PSU's. All of this was built for less than $300 including the case (from Par-metal). This DAC is one of the best I have ever heard, I've listened to many digital converters including the ESS Buffalo DAC with Pass D1 IV this, one seem's to sound just slightly better in the control of the bass frequencies and the treble is slightly more crisp. I would like to know what changes could be made to improve the subjective sound quality even more, (I'm pretty new to DAC design). Any suggestions are welcome, Thanks.
I suggest ditching the off-the-shelf digital filter and rolling your own with a lightweight DSP chip like ARM Cortex M4. I reckon 2X OS sounds best with a minimum phase filter - not linear phase like with the standard filter parts. Also try without the ASRC as this has built-in linear phase filtering too.
Hi it is not that interesting what I think as I count other features than sound quality too in the final verdict like easy of implementation, availability, etc.
Purely sound wise I have a weak spot for TDA1541A, AD1865 and FN1242a without ranking one or another higher than the other as they all have their specific merits. Since I am into ES9023 now I rank that one pretty high too. The latter is the most easy to implement and outperforms many PCM and even WM874x types. If it is better than TDA types I can not tell. Haven't compared as I haven't any TDA based DACs anymore. One of the members will be comparing the ES9023 with TDA1541A based DACs soon but unfortunately his ES9023 DAC is not playing because of an error. To be honest that comparison is the most interesting to me.
All is relative of course and it also depends on taste. The better DACs are the one you don't expect to be good. I recall what I experienced with the so-called Lawrence CS4397 DAC after modification. I like DACs to sound analog-like with lots of spacial information, depth and real life like highs. As soon as a DAC has any metallic like highs I switch it off 😉
Hang on in JP... once I have your ES9023 DAC finished (psu is ready...) I will of course compare it to my latest gen Audiosector DAC. 😉
OK, that one is interesting too as the Audiosector are good sounding DACs. But we are stealing another members thread. I am outta here !
thanks jean paul , for the moments i experiment a single TDA1543 " à la mode" audio sector sounds very good but can't say more it's my first one.
but as Dac "addict" i had ( audionte ad1865 , berkeley alpha, weiss 202 , acoustic arts tube dac, lessloss 2004, wadia 25, audioaero 24/192, PASS D1, JADIS JS2, EAD DSP900, etc...)
and my top 3 are Audio note, berkeley and audio aero.
do you have a link for your ESS9023 dac ,even if the only sabre dac i had ( Weiss) was not my taste at all..
best ever? not yet imho, not with those generic carbon resistors 🙂, try metal film such as takman, dale cfm..just teasing you..
Nakamichi DAC101
Just wanted to direct your attention to this DAC if you are into TDA1541. This unit is made for car entertainment, but it contains two TDA1541A S1 Single Crown in what seems to be differential mode. I got hold of one from Ebay. They show up from time to time. Are in the process of disconnecting the built in switch mode power supply (12v to +- 15 and 5v) and change to an analog supply.
nakamichi ‚c‚`‚b�|‚P‚O‚P‚̉ü‘¢
The schematics I have gathered from the internet are at the bottom here:
http://www.diyaudio.com/forums/car-audio/137271-nakamichi-cdc101-dac101-sm.html
Can you point to any finished project/kit using DSPs as digital filter which have better performance then off-the-shelf ICs?I suggest ditching the off-the-shelf digital filter and rolling your own with a lightweight DSP chip like ARM Cortex M4...
I'm working on a similar project and I'm also stuck to off-the-shelf DFs (DF1706) and/or software oversampling (up to 176.4k or 192k). I am aware that ADI have their SHARK Melody or Motorola DSP56364 specifically for this but don't know any DIY projects using these or alike.
Thanks!
No, I can't point to one published online - I've done it myself using LPC1313 though into a 16bit DAC (TDA1545A) but I haven't posted up details.
I prefer to use ARMs because they're normal CPUs with DSP facilities so are much easier to understand and code for than the true DSPs like you mentioned. Also much lower power and hence lower noise. If you'd like to find out more, have a look at this thread : http://www.diyaudio.com/forums/digital-line-level/195791-open-source-dsp-xos.html
Benproiii - nice work! What value did you use for the i/v resistor?
Thanks everyone for there feedback, the IV resistor I used was 2.3k dale 0.01% which makes 2.3v p-p output with 1ma of current in from the dac chips.
I could post the schmatics if any one wanted them.
I've used 100r < Rx < 1k for the resistor, but never so high before, doesn't that lead to some kind of distortion?
Very much agree. The sound would definitely be better with an "Riv" of 100-200ohms. Gotta be hitting some distortion with 2.3k.I've used 100r < Rx < 1k for the resistor, but never so high before, doesn't that lead to some kind of distortion?
I don't use resistor for iv I use a grounded gate amplifier so the dac sees virtual 0 ohms iv. There is a resistor on the drain of the fet that sets the gain of the amp that's the 2.3k I thought you meant That is the iv resistor.
The iv stage is a modified pass d1 with 3 ccs's
I would like very much to see the schematics .
- Digital Source
- AD1865 & Pass D1 = Best DAC ever
